It is currently Aug Mon 03, 2020 4:33 pm
 Post subject: Replacing ceramic discs with polypropylene?
PostPosted: Sep Thu 12, 2019 2:19 am
I am working on a old Nordmende, and there are 3 ceramic discs that are falling/flaking apart. I was just barely able to ID them as .0047uf (4700pf), because of their difficult location and my 52 year old eyes are getting worse.
Question is, I have .0047uf polypropylene laying around. Can use them? A google search was inconclusive. The audiophile people must be nuts. Other say you should use ceramic in bybass or temp sensitive circuits. Problem is, I cannot ID where they are in the schematic. So I am asking the experts here.
 Post subject: Re: Replacing ceramic discs with polypropylene?
PostPosted: Sep Thu 12, 2019 4:24 am
Simply note which tube circuit they are in, and then you should be able to ID them on the print. I would definitely replace like for like in this case, esp if they are in the osc circuit. The manufacturer used disc caps in the locations they are in, for a reason.
PostPosted: Sep Thu 12, 2019 7:44 pm
Hi N4NYY,
I agree with above advice by "fifties". Assuming that this radio is original, the significant thing is that only three ceramic disc caps were used. As "fifties" says, this was no doubt done for a reason. You were fortunate to be able to identify their value; perhaps this will help in identifying them in the schematic. But in any case, I would definitely use ceramic discs for their replacement.
Poston
PostPosted: Sep Thu 12, 2019 7:58 pm
That is the reason I ask the experts. I will replace with the same.
PostPosted: Sep Thu 12, 2019 9:27 pm
Have you unsoldered 1 end and tested them? American disc caps don't go bad that often. Euro disc should be about the same quality or better. On the other hand, i have seen Euro oil caps that you would think are good and have tested bad for leakage.
PostPosted: Sep Thu 12, 2019 9:51 pm
They are flaking and cracked. One split into half.
PostPosted: Sep Thu 12, 2019 11:13 pm
You don't state whether all (most) of the capacitors are ceramic, or just the 3 and they are flaking.
If there are only 3 ceramics and the rest are film caps, then the chances are they were used for a reason.
PostPosted: Sep Thu 12, 2019 11:16 pm
The 3 discs are flaking cracking. The other ceramic caps look more like a dogbone resistor shape. They all look good. They are not disc, despite being the same value.
PostPosted: Sep Thu 12, 2019 11:42 pm
+1 to that.
As others have said, we can't help you choose the type to use if we don't know where they are in the circuit. So the best advice is replace them with the same type.
Parts that are broken in half need to be replaced. The problem is how did it get that way? If it was physically abused, just replace it. But i have seen ceramic capacitors burn in half or even burn completely away leaving only the wires. If that happened, you really need to determine where they are in the circuit so we can guess at what happened and what to do about it. Otherwise, it may happen again.
In general, ceramic capacitors are very reliable and seldom need to be replaced.
Jim Mueller
PostPosted: Sep Thu 12, 2019 11:55 pm
Ok, so it sounds like you have tubular ceramics elsewhere. I would be thinking that maybe these were used to achieve a particular temperature coefficient that was not available in the tubular ones. Not knowing where they are in the circuit makes it important to replace only with ones of the same temperature coefficient- just in case. If you knew where they were, you could make a decision based on their use in the circuit.
PostPosted: Sep Fri 13, 2019 5:19 am
+1 to that.
The best course of action is to buy at least two or three of each value. If the first replacements burn out, you'll have backups to use once you determine the cause of the problem. Ceramic caps are quite cheap.
PostPosted: Sep Fri 13, 2019 12:15 pm
It is always the best practice to replace components with the same types originally used. Substituting different parts is essentially random re-engineering. Chances are whoever designed the radio put considerable effort into finding exactly the right capacitors to give the desired level of performance. Put anything else in there and the performance will probably not be the same, and odds are it won't be better.
Even if those ceramic discs are only used as bypass capacitors, they could be critical to proper performance. Capacitors have self resonant frequencies and inductances; no polypropylene cap will match a ceramic disc on those characteristics. If the Nordmende has FM, those things could make the difference between working well and barely usable, or maybe not working. Not only would I use ceramic discs for replacements, I would ensure that the physical size (diameter) of the new ones is the same as the old ones to try to keep the characteristics as close as possible to what was originally there.
PostPosted: Sep Wed 18, 2019 2:43 am
I have always replaced "like for like". the engineers know more than I do for deciding upon what type of capacitor goes where. they chose a particular style for a reason.
if it were a ceramic disc, it gets replaced with a ceramic disc.
if it were a foil/film capacitor, it gets replaced with a foil/film capacitor.
if it were a silver mica capacitor, it gets replaced with a silver mica capacitor with close to matching temp coefficients.
so on and so forth...
steve
-Churchill
PostPosted: Sep Wed 18, 2019 3:08 pm
No, no, no, the audiophile's know what they are talking about! However this is RF and if you use poly caps in RF circuits your highs will be brittle and your lows will be muddy. Polite people do not even speak of what they do to the mids....
Seriously however, ceramic caps are generally better for RF applications. They may make little difference in the AM band but at the high end of the HF band they could make a big difference. If these caps are in the audio section then you could use polys but even there they sometimes serve as RF bypass caps so at the end of the day the best practice is to always replace like with like. If you are really keen to get a radio going today we will grant you dispensation to try whatever you have on hand until the proper replacements arrive!
PostPosted: Sep Wed 18, 2019 7:52 pm
Thx for the belly laugh! :wink:
PostPosted: Sep Wed 18, 2019 9:46 pm
I don't see mention of the model number or a link to schematic.
Bill J.
