It is currently Jul Sat 11, 2020 8:12 am
 Post subject: Amperite 3A20--Help needed.
PostPosted: Oct Thu 17, 2019 11:12 pm
I found a NOS Amperite 3A20 in some tubes from an estate. I tried to research it on the web but not much help.
Any info. would be appreciated.
Harold
 Post subject: Re: Amperite 3A20--Help needed.
PostPosted: Oct Thu 17, 2019 11:36 pm
That is a current regulator ballast tube.
Not sure what its ratings are though, yet.
http://www.labguysworld.com/AMPERITE_BALLAST_TUBES.pdf
Paul
...... how hard can it be?
PostPosted: Oct Fri 18, 2019 1:31 am
Harold
Regulates at 300 ma with voltage between 20 and 41.
PostPosted: Oct Fri 18, 2019 2:04 am
Norm Leal wrote:
Harold
Norm, where did where did you locate the rating?
Paul
PostPosted: Oct Fri 18, 2019 2:07 am
The Ballast Tube Handbook.
It's also in Radio Electronics Master. This is a large book which came out every year and given by Distributers.
PostPosted: Oct Fri 18, 2019 2:32 am
Thanks. I do not have those books--very interesting.
Harold
PostPosted: Oct Sun 27, 2019 4:46 am
For someone who has a particular Jackson VTVM, a 3A20 tube is used in that unit.
viewtopic.php?f=8&t=334464&hilit=3a20
Probably nothing else requires that tube.
PostPosted: Oct Tue 29, 2019 8:44 pm
Here is a PDF version of the ballast tube handbook.
https://www.americanradiohistory.com/Ar ... ok-opt.pdf
-Jeremy
