It is currently Aug Fri 07, 2020 5:05 pm
 Post subject: 7 Watt Bulbs
PostPosted: Nov Mon 04, 2019 10:22 pm
Can anyone tell me where I could buy 7watt-115 volt bayonet bulbs . I have 2 CGE.Model C600 that needs them.
 Post subject: Re: 7 Watt Bulbs
PostPosted: Nov Mon 04, 2019 10:32 pm
Walmart might have clear C9 Christmas lights out now.
Sorry not bayonet. I've not seen one before.
PostPosted: Nov Mon 04, 2019 10:35 pm
Single or dual contact??
DM
PostPosted: Nov Mon 04, 2019 10:38 pm
I couldn't find one at 1000bulbs.com, but try there.
PostPosted: Nov Mon 04, 2019 10:43 pm
They are double contact with pins at same height on each side.
PostPosted: Nov Mon 04, 2019 10:44 pm
I see several on E pay - 7 watt 130 bayonet bulb search.
Also used on some over the range microwaves for the dim (night light) bulb.
Local electric supply store or appliance dealer might keep in stock.
Dan
PostPosted: Nov Tue 05, 2019 1:01 am
You're looking for 6S6DC-120V (or 145V if you never want to replace them). There are LED replacements too, but I don't know how evenly they would light (but would be much less heat). I would think I'd find them in Lowes; probably not at Wal-Mart.
PostPosted: Nov Tue 05, 2019 1:16 am
Our Kenmore vacuum uses something similar.
-Ed
PostPosted: Nov Tue 05, 2019 3:43 am
Thank you guy's I will check some of these places.
PostPosted: Nov Tue 05, 2019 4:55 pm
Years ago I was looking for one to replace a Zenith dial light, ended up finding one at a sewing shop, turns out they are used on sewing machines.
PostPosted: Nov Tue 05, 2019 4:58 pm
-Ed
Every Sears vac I've seen uses a 15W, too high wattage & heat.
The S6 lamps have dual contacts came in several wattages.
Common on ebay BUT make sure they are bayonet, also available in candelabra base.
https://www.ebay.com/itm/Lot-of-12-GE-6 ... SwnF9Y76jU
PostPosted: Nov Tue 05, 2019 10:42 pm
Mc master Carr has them in all voltages (6S6). I use the LED version when I can. I have some old commercial switch gear that uses them.The LED’s last a lot longer and give good brightness. I even use the LED’S when replaying my home Night lights.
PostPosted: Nov Thu 07, 2019 12:19 am
I refurbished a white, plastic CGE Model C600 a few years ago... and was surprised by the huge dial lamp! It had a good lamp, but much too bright for me! I think I wired in a series resistor to make it more amenable, but I no longer have the radio to check.
Cheers,
Roger
EDIT
PS. The smart move would be to use a series capacitor so as to dissipate no power (heat.) I don't recall doing this... might have!
Roger Jones,
Thornhill, Ontario
PostPosted: Nov Thu 07, 2019 12:28 am
I contacted a sewing machine place today he had 15w at 115v but to hot to fit in, but he had socket for screw in bulbs so I think I will go that way.
PostPosted: Nov Thu 07, 2019 6:40 am
Would a diode tame the 15w bulb down a little?
PostPosted: Nov Thu 07, 2019 9:49 pm
Also a cap should work.
PostPosted: Nov Fri 08, 2019 8:04 am
Grainger has these:
https://www.grainger.com/product/LUMAPRO-6-0-Watts-Incandescent-Lamp-4RZW5
https://www.grainger.com/search?searchBar=true&searchQuery=6S6DC-120V
Ted
PostPosted: Nov Fri 08, 2019 7:03 pm
Thank you everyone for the places to try. Thank you Ted I ordered them from Granger and they have to get from supplier so 2 to 3 weeks.
PostPosted: Nov Sat 09, 2019 7:19 pm
Even small incandescent bulbs seem to be going the way of the drugstore tube tester. Vendors that had a good selection even pretty recently seem not to have many for sale these days.
Better get 'em while you still can.
Ted
Users browsing this forum: Sick Dog, sprman, stevebyan and 19 guests
