It is currently Aug Thu 13, 2020 3:51 am
 Post subject: Source For Speakers?
PostPosted: Nov Tue 05, 2019 2:42 pm
I have 2 radios that each need a 5" permanent magnet speaker with mounting holes on the surround, including the Hallicrafters S38 I'm working on. In the past I've been able to find suitable replacement speakers at Play Things of the Past (http://www.oldradioparts.com/), but sadly, the owner has been having some health issues and the site is closed until March. Cancer sucks...I hope he beats it. But now I need to find another source. I've done a little searching and didn't find anything so decided to try here before expanding my search.
Where do you guys find replacement speakers?
Thanks!
 Post subject: Re: Source For Speakers?
PostPosted: Nov Tue 05, 2019 2:51 pm
OMG, sure hope Gary makes a recovery
PostPosted: Nov Tue 05, 2019 11:38 pm
Try a WTB ad in the classifieds here on ARF ? Someone probably has something close enough.
PostPosted: Nov Tue 05, 2019 11:49 pm
Radio club swap meets. Brand new speakers.
PostPosted: Nov Wed 06, 2019 2:53 am
Thanks for the suggestions guys! By the way, how are speakers measured? I've always assumed it was outside edge to outside edge. Is that correct?
PostPosted: Nov Wed 06, 2019 3:07 am
Parts Express is an excellent source of modern up-to-date speakers, woofers, mid ranges, tweeters, and more. The prices range from reasonable up to “high-end.” So does the performance. As a long- term audiofool, I can tell you that today’s speaker technology is way more advanced than it was as recently as 20 years back. There are far more sizes and designs available, and some (not all) are very scientifically designed and tested.
The following item just might be adaptable to working in a vintage radio:
http://www.parts-express.com/visaton-fr13-4-5-full-range-speaker-4-ohm--292-518
-EB
I’m learning to be a leading-edge designer of trailing-edge technology.
PostPosted: Nov Wed 06, 2019 3:15 am
Another large vendor of speakers and related parts:
http://www.madisoundspeakerstore.com/index.php?p=home
-EB
PostPosted: Nov Wed 06, 2019 9:05 am
Ebay has a ton of 5" speakers.
PostPosted: Nov Wed 06, 2019 3:07 pm
Thanks for the ideas guys! I appreciate it.
PostPosted: Nov Wed 06, 2019 4:30 pm
In my experience, finding the right size is seldom the problem. Usually the problem is finding a direct bolt in replacement with the same screw-hole pattern.
But even the wrong hole pattern does not need to be a deal breaker. Usually and adapter can be fabricated to make the transition to a new speaker hole pattern.
Paul
...... how hard can it be?
PostPosted: Nov Wed 06, 2019 6:40 pm
I agree processhead. I'm pretty sure I can create an adapter on the 3D printer if I can find a suitable speaker. I've been through hundreds of listings on eBay but have not found anything that looks like it would work.
How much do I need to be concerned about impedance? The one in the S38 measures 2.3 ohms. I'm sure a 4 ohm would work...what about 8 ohm?
Thanks.
PostPosted: Nov Thu 07, 2019 12:26 am
DC resistance of a speaker is usually slightly less than the rated impedance.
A “4 ohm” speaker is the ideal impedance for most radios.
But an “8 ohm” speaker will still work and won’t cause any harm.
-EB
PostPosted: Nov Thu 07, 2019 12:28 am
1/8” thick Masonite is a useful material for making speaker adapter plates out of.
-EB
PostPosted: Nov Wed 13, 2019 8:50 pm
Hi Rich
I sometimes refer to these guys:
https://www.goldmine-elec-products.com/ ... ?dept=1217
billn
