It is currently Jul Sat 11, 2020 8:39 am
 Post subject: 1962 Panasonic 740 neon bulb source
PostPosted: Nov Sun 10, 2019 10:49 pm
I just found a Panasonic 740, found an open resistor so it is playing fine HOWEVER the neon pilot bulb is dead. power to the socket so the bulb needs a replacement. Any ideas on where to obtain one?
"CIVILITY IS RECIPROCAL"
 Post subject: Re: 1962 Panasonic 740 neon bulb source
PostPosted: Nov Mon 11, 2019 2:40 am
OK I'll bite. Which neon bulb does it use?
Henry
PostPosted: Nov Mon 11, 2019 3:27 am
With a Panasonic (Matsushita/National) part number, you can likely find more info either at Union Electronics/UED.net or Encompass (formerly TriTronics).
Got a manual? I may, on microfiche.
Brian
PostPosted: Nov Mon 11, 2019 5:27 am
The bulb has a standard bayonet base and looks like a #47. There are no markings on the metal base and the parts list in the Sams document fails to mention a type or part #. The bulb is used as the pilot indicator in the upper right corner of the front.
PostPosted: Nov Mon 11, 2019 6:38 am
Sounds like a NE-51 bulb.
Newer part number is B1A.
Scott.
PostPosted: Nov Mon 11, 2019 8:45 am
Sounds like Scott is correct, schematic shows a neon bulb with a 100K resistor in series across 120 vac.
DM
PostPosted: Nov Mon 11, 2019 5:39 pm
The resistor checks OK. I'll look for a bulb, B1-A. This is the last step to completion of the Panasonic. It is a large plastic hand wired radio with a 6" speaker and tone control. Never seen one. Performance is nice. Thanks everyone!
Users browsing this forum: azenithnut and 11 guests
