It is currently Jan Thu 27, 2022 6:43 pm
 Post subject: Telefunken ID52V restoration
PostPosted: Sep Wed 22, 2021 6:21 pm
Hello,
I have just purchased a Telefunken ID52V radio and looking for someone to restore it four me in the UK. I want to keep the outside look but get it in -perfect working order.
Would anyone know of a person who would take this on?
Secondly does anyone know if I am missing the separate what I think power pack?
Adrian
 Post subject: Re: Telefunken ID52V restoration
PostPosted: Sep Fri 24, 2021 5:48 am
https://www.radiomuseum.org/r/telefunke ... id52v.html
You may just have the RF section ad not the whole radio .
Mark
PG-18-23909
PostPosted: Sep Fri 24, 2021 3:50 pm
Battradio yes I believe I am missing the power pack so just need someone who know what part this is or a code so I can search it out to restore this one if possible :)
PostPosted: Sep Mon 27, 2021 12:26 am
Hi,
Your car radio is almost complete, what you have contains the five valve circuit, from RF to audio.
The only thing missing, as you correctly guessed, is the power supply, that takes in 6V DC from the battery and converts it to high voltage. It contains a vibrator, a transformer, and a selenium rectifier.
If you look at the picture of the power supply (on the radiomuseum web site mentioned in Battradio's response), its label doesn't show a specific reference, but only says Stromversorgungsgerät Type ID52V - 6 Volt (Stromversorgungsgerät simply means power supply)...
The schematic does not provide a reference or code for the power supply either. This being said, it tells you everything you need to know to build your own power supply ;-)
Experience is directly proportional to the amount of equipment ruined. (Harrisberger's 4th Law)
cron
