Page 1 of 1
[ 8 posts ] |
Author |
jim rozen
Post subject: couple of cool tubes Posted: May Fri 27, 2022 3:42 pm |
Joined: Mar Wed 16, 2011 10:44 pm Posts: 2375 Location: Peekskill, NY
Top |
Indiana Radios
Post subject: Re: couple of cool tubes Posted: May Tue 31, 2022 2:40 pm |
Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 15439 Location: Carmel, Indiana
Thier all basically differant versions of the WD-12: https://www.radiomuseum.org/tubes/tube_wd12.htmljim rozen wrote: The other two are CX-12s also cunningham, with the interesting feature that those two have *both* a flashed getter and a lime getter on the press. Never saw that before. Most likely a product of a transitionary period for Cunningham in which they were phasing out the older lime getter in favor for the more modern flash getter.
_________________ Michael Feldt
www.indianaradios.com
Top |
phlogiston
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 3:05 pm |
Member |
Joined: Dec Thu 31, 2009 4:28 pm Posts: 5144 Location: Under the Blue skys of OR 97524
Have you verified the heater voltage on each? 1.1V?
Russ
_________________ "I just might turn into smoke, but I feel fine" http://russoldradios.com/
Top |
jim rozen
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 3:54 pm |
Yep, the two bakelite base tubes are in the radio, in use to good effect. I can't quite bring myself to fire up the brass base one yet. So for now it's only one stage of audio. All being run off a single D cell for the filament supply. (how many Ah was a number six dry cell back in the day?)
Top |
phlogiston
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 6:21 pm |
Member |
I would not run the BBT one either. It is probably more valuable than most radios that it would be used in.
Top |
jim rozen
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 6:40 pm |
It's an agonizing decision. In fact the tube was a dud when I got the set, until I re-flowed the pins. It was in the detector socket of that regen set linked to in the general site. I might want to give a try, "just this once..."
Top |
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 9:03 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 17887 Location: S. Dartmouth MA 02748-1225 USA
(how many Ah was a number six dry cell back in the day?)25 amps... When I was a boy these were $1.25 each. But my weekly allowance was .70 cents...
_________________ List' & I will Enchant Thine Ear
Top |
phlogiston
Post subject: Re: couple of cool tubes Posted: Jun Wed 01, 2022 9:13 pm |
Member |
I have to admit giving you "off the shelf" advice. I would try it too. Then wrap it up nicely. Just be vey careful. I don't think there is a "dim-bulb" that would work for this tube. Maybe just power the filament off of a rechargeable (lower voltage) dry cell, AA battery. Make sure that it lights prior to B+ being applied.
Russ
Top |
Page 1 of 1
[ 8 posts ] |
Who is online |
Users browsing this forum: Jim Mueller and 11 guests |
