It is currently Oct Tue 20, 2020 3:51 pm
 Post subject: Oversize Schematics
PostPosted: Feb Tue 06, 2018 9:52 pm
Hi All,
I’m finally getting around to my first restoration, an Emerson 652B. I’ve gone through several YouTube videos and notice the use of way oversize schematics. Since my eyesight is not all that good, does anyone know where to obtain those large copies? Are they available only for certain manufacturers or can one take an 8-1/2 X 11 to Office Max and have them copy the original to a larger size without compromising clarity legibility?
Any tips greatly appreciated.
Ed
 Post subject: Re: Oversize Schematics
PostPosted: Feb Tue 06, 2018 10:09 pm
Taking Rider's as an example, many of the scans available are not that good. One of the better sources is americanradiohistory (dot something). I have one of the "hi-res" DVDs from EBay. They are better than nostalgiaair, but not as good as American Radio History.
You'll get the best result by first cropping and maybe some "tuneup" in a photo editor, and then getting them printed at 11x17.
13x19 is even better, but...at many print shops...costs a lot more. For this, I'd just buy an inkjet printer.
PostPosted: Feb Tue 06, 2018 10:47 pm
Yes, as Mark mentioned, first locate a good clear copy of your schematic.
Then I have taken them into an office supply store and have them printed on a large format copier or even a large photo plotter like architects use for large floor plans. These only cost me a couple of bucks.
G.
PostPosted: Feb Wed 07, 2018 1:34 am
If the schematic is a .pdf file, Adobe Acrobat Reader lets you print poster size.
It will print the page over multiple 8.5" x 11.0" sheets. at 190% it will print on 4 sheets. It will print cut lines,
where the sheets overlap. I cut on those lines and tape the sheets together for a larger
schematic.
PostPosted: Feb Wed 07, 2018 4:07 pm
Most Staples have a copy center where they can print on 36" wide paper. Even if enlarged to 24x36 should cost less than $4 each.
AA5LP
PostPosted: Feb Wed 07, 2018 4:33 pm
I do what Dave suggested , print them out cut and tape together.
PostPosted: Feb Wed 07, 2018 4:36 pm
If you 24x36 or up to that size, consider a 24" roll fed plotter, color inkjet, Canon and HP make them.
For less than a $1000. I work for a Canon dealer, we do large format exclusively. But you can go to Amazon or eBay and get them too.
https://www.amazon.com/Canon-imagePROGR ... at+Printer
edit: A customer can send us the pdf file, we charge about .40 per sq ft, so a 24x36 would be $2.40. Check your area for a blueprint shop, they all use
digital printers now.
PostPosted: Feb Wed 07, 2018 8:19 pm
Wow! Looks like several ways to go, all good!
Thanks to all who responded with these great solutions.
Ed
PostPosted: Feb Thu 08, 2018 3:42 pm
Yeah you can do a lot with a good clear copy, but.. I find the best copy I can, paste the image into DeltaCad and trace it out.. I clean up and correct anything that needs it and add notes to my liking.. Then print it out on multiple sheets as someone already mentioned.. A laser printer is what I use.. It gives the best detail..
BTW,.. DeltaCad gives you the option to scale it any size you want..
Stan
Stay coordinated.. and remember, altitude is your friend..
PostPosted: Feb Thu 08, 2018 9:37 pm
Laser is nice, but if your original isn't 1200 dpi it does not matter at all. much higher resolution isn't usually processed above 1200.
The new Canon c750imagePress for example can print 2400x2400 (32 beams- 4 lasers), but the controller only runs at 1200dpi.
We do line drawings for our customers at 200 or 300dpi, it maintains a good file size and has all the quality it needs, and we print truckloads of it.
If you really want bigger drawing and have the cash I'd get the 24" plotter, offers color, prints up to 24"x36" or as small as you want too.
Forget laser, that's for cut sheet and not worth anything extra for drawings.
Do NOT buy a Kipper plotter, if they are throwing it away, there's a reason, they are junk and expensive to run.
Or email your file to my shop, we'll print and mail to you for a few bucks.
PostPosted: Feb Fri 09, 2018 2:51 am
+1 on Dave's suggestion. Of coarse it may not improve legibility if original is not all that good. But at least it will be large enough to add tube pin numbers and resistor and capacitor values if not on schematic but on parts list. And you don't have to squint.
PostPosted: Feb Fri 09, 2018 2:22 pm
Also what Dave suggested except that the percentage will change depending on the original files resolution.
The higher the resolution of the scan, the lower the percentage needed. You can play around with it and it will show in the window on the right.
Steve Johnson
https://stevenjohnson.com - Steve's Antique Technology
PostPosted: Feb Fri 09, 2018 3:01 pm
Not going to argue over printers.. when you can't read the original, you have to go the extra mile.. What I said was, I print them on a laser AFTER I redraw/clean it up it in a CAD program.. You can't do better than that.. I end up with a very nice, crisp, clear copy.. Most I've done look really good on 8.5"x 11.0".. but I have scaled some and printed them on multiple sheets..
And you can't beat FREE..
PostPosted: Feb Sat 10, 2018 12:57 am
Tried Dave's suggestion last night. Played a bit with magnification and got great result.
Thanks again all.
Ed
PostPosted: Feb Sat 10, 2018 1:35 am
schematic.
I learned something new. It worked for me in Adobe Reader 11. Thanks, Dave!
Post New Topic Post Reply  [ 15 posts ]  Moderator: Alan Voorhees
Users browsing this forum: jsowers, wyocodak and 20 guests
