It is currently Oct Wed 28, 2020 4:44 am
Post New Topic Post Reply  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: Flat speaker wire?
PostPosted: Nov Sun 10, 2019 12:05 am
I've been looking at "flat" speaker wire to run under about 5' of carpet. The "ghost" wire uses a flat copper ribbon, is adhesive backed, and terminates in standard lug connectors. Anyone have any recommendations? I only need a few feet; standard zip cord will suffice for the remaining hidden runs.
Dan
 Post subject: Re: Flat speaker wire?
PostPosted: Nov Sun 10, 2019 1:03 am
Would 300 Ohm flat twin-lead work?
PostPosted: Nov Sun 10, 2019 2:09 am
See if this is similar to what you want: https://www.parts-express.com/cat/flat- ... -wire/1619
But it is not adhesive back it does not seem. I have seen what you describe somewhere but in the past, so sticky back ribbon speaker wire may be a problem.
PostPosted: Nov Sun 10, 2019 9:22 pm
I made mine out of 3M copper foil tape and very wide Christmas wrapping ribbon. We had low nap carpet and that's the only thing that wouldn't show through.
PostPosted: Nov Sun 10, 2019 9:54 pm
That's a good idea; wire is wire. Nothing spechul here.
PostPosted: Nov Mon 11, 2019 8:03 am
Apply two lengths of this to another tape or ribbon as macrohenry suggests. Plenty here to do the job, 36 yards! https://www.sciplus.com/conductive-copper-tape-63233-p
My life is loosely based on a true story.
PostPosted: Nov Tue 12, 2019 10:02 pm
Yes, and it won't ruck up if the carpet does not move.
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Nov Tue 12, 2019 10:59 pm
I would not run much power thru 300 ohm twinlead because of the small gage and also the added series resistance if very long. And the conductors would be easily broken if any stress put on them.
PostPosted: Nov Wed 13, 2019 9:11 pm
Thanks for the tips and links - - I appreciate your help. I stumbled upon this stuff, and figured it would be worth a try. One under-carpet run is a bit tricky; I have bell wire under there now (old, OLD bell wire, and the insulation's crumbling), and can use it for pulling the new stuff through. I do like the copper foil idea. I'd used it to repair stained glass many moons ago, and I'd completely forgotten about it.
The seller accepted $7 for 2-50' rolls, with $8 shipping; I don't know how they can do it for the price, but who am I to question a good deal?
https://www.ebay.com/itm/2-50ft-Reels-R ... 2749.l2649
Dan
PostPosted: Nov Thu 14, 2019 12:14 am
Quite right... I should have said "keep it short".
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Nov Thu 14, 2019 12:40 am
you can cryogenically treat the 300 ohm twin lead, which will not only align the molecules for superhuman strength, but also make the highs higher, the lows lower, and the spatial geometry more ..... geometric. Or more spatial, I forget which now ... it may also act as a WOW!!! filter. WOW!
Oh wait, this isn't an audio website???? never mind........;-)
PostPosted: Nov Thu 14, 2019 1:40 am
^^^ make sure the twin lead is oxygen free copper for best sonics.
PostPosted: Nov Thu 14, 2019 10:49 am
Sorry to be worry wart but under carpet wiring has a big *ugly* rule dog
standing guard.
In Canada rule 60-326 d says communication flat cable type CFC is
prohibited in dwelling units.
WHAT ? That darned book is 900 plus pages long.
(I'll go back o sleep now) :D
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Nov Fri 15, 2019 9:25 pm
Actually, it does say oxygen free on the label. Maybe I should snag 500 feet, carefully cut it in custom lengths with ceramic dikes, and ship it in sealed nitrogen filled bags. Wrapped in foil, of course. What a great way to boost my retirement income! Thanks for the idea. :lol:
Dan
PostPosted: Nov Fri 15, 2019 9:32 pm
standing guard.
You northerners need to live life more on the edge! The vicarious thrill of running speaker wire under 6 feet of carpeting has set me all aquifer. . .even my wife is positively giddy at the very thought :lol: :lol: :lol:
Dan
PostPosted: Nov Fri 15, 2019 9:37 pm
While you're at it, how about running some 1/4" polypropylene tubing on a 4" grid, and run heated water through it ?? ;-)
....just a thought......
PostPosted: Nov Fri 15, 2019 9:50 pm
Barry - - the house I grew up in had radiant heat in the terrazzo floors, but it was 1" steel tubing on 12" centers. It was absolutely wonderful; completely silent, and 72 degrees indoors when it was 0 outside. The bathtub and shower floor was always warm, as were your shoes and boots in the winter. My father was an architect, and a big fan of Frank Lloyd Wright designs; he designed a budget-conscious version of one of Wright's houses. Unfortunately, the tubing failed after 60 years; it was gas-welded together, and the lime in the cement rotted away the welds. After my mother passed, the house & acreage was sold, and they tore the house down to make room for a McMansion subdivision. Very sad to say the least.
Dan
PostPosted: Nov Sat 16, 2019 2:30 am
Hey ! Best idea of all. Forget retirement. Just jump into a sealed bag of
nitrogen (liquid of course), ideal oxygen free environment, and leave a note
when you want to be thawed out.
Dave, Have you really thawt about this ?
No, Hal.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Nov Sat 16, 2019 11:24 pm
you can cryogenically treat the 300 ohm twin lead, which will not only align the molecules for superhuman strength, but also make the highs higher, the lows lower, and the spatial geometry more ..... geometric. Or more spatial, I forget which now ... it may also act as a WOW!!! filter. WOW! Oh wait, this isn't an audio website???? never mind........;-)
Pure poetry... thanks!
Cheers,
Roger
Roger Jones,
Thornhill, Ontario
PostPosted: Nov Sun 17, 2019 3:14 pm
Well, except that twin lead is designed for RF and the wire is only 22 ga. Not suitable for speaker wire. It'll work for very short runs, but I wouldn't run e.g. a set of AR3's with it.
John Stone
Post New Topic Post Reply  [ 34 posts ]  Moderator: Alan Voorhees Go to page 1, 2  Next
Users browsing this forum: Adam Vaughn, beat_truck, Dirt Bomb, RQuam, Terry Judkins, tolikkk, Tom Schulz, westcoastjohn and 24 guests
