It is currently Jan Fri 17, 2020 8:30 pm
 Post subject: Universal Schematic Locator - on a MAC ?
PostPosted: May Mon 30, 2016 1:31 am
Anyone comp gurus out there have any idea how to make the Universal Schematic Locator work on an Apple computer ? Sure would be nice.
.....Dennis.....
Live Long and Prosper
 Post subject: Re: Universal Schematic Locator - on a MAC ?
PostPosted: May Mon 30, 2016 2:01 am
It is a Windows executable, so it would need something like WINE to allow a Windows application to run.
https://www.davidbaumgold.com/tutorials/wine-mac/
Or, install Windows on your Mac and make it a dual boot machine?
PostPosted: May Mon 30, 2016 2:44 am
I use CrossOver to run windoze programs on my MacBook Pro.
It works fine.
PostPosted: May Mon 30, 2016 3:07 am
You can download the zip file and unzip it. The indexes reside in three ascii text files named BINDEX.txt, RINDIX.txt, and SINDEX.txt. The format is a little odd - it appears to be tilde-separated fields. I haven't deciphered the structure of the files, but I don't think it would be too hard to figure it out.
Once you understand the schema, it should be pretty easy to import it into FIlemaker and set up a search window.
PostPosted: May Mon 30, 2016 7:02 am
The files are just like CSV. files, except they use tildes instead of commas.
That's pretty much it, except there is one column that contains alternative make information that the program can key on to generate more relevant hits ( airline for Montgomery ward and silvertone for Sears Roebuck, for example).
The program should run perfectly with any reasonably competent Windows emulator.
-primitiveradiogod, author of the USL.
PostPosted: May Mon 30, 2016 12:54 pm
Thank you to all who responded.
I installed the WINE app and was able to install the USL on my Mac.
It functions fine.
.....Dennis.....
PostPosted: Nov Thu 21, 2019 11:51 pm
Bummer.....here we are in 2019, and Apple has released their lates OS (Catalina).
Turns out Catalina will run only 62bit apps. Universal Schematic Locator is a 32bit program, soooo the nifty little program no longer works on my Mac. Another good reason that I still have my clunky old Windows PC down in my workshop....
.....Dennis.....
PostPosted: Nov Fri 22, 2019 12:05 am
I never upgraded my iMac since it came with Mountain Lion.
I know it will run more recent versions of OS X but decided not to pursue that route.
PostPosted: Nov Fri 22, 2019 2:00 am
that link needs to be deleted.
it leads to a sleazy domain squatter that tries to trick you into installing malware/crapware.
[quote="Dennis Wess"]Anyone comp gurus out there have any idea how to make the Universal Schematic Locator work on an Apple computer ? Sure would be nice.
PostPosted: Nov Fri 22, 2019 2:19 am
Yes, same here, that is exactly how you get viruses and malware, do not install anything from that site.
PostPosted: Nov Fri 22, 2019 2:24 am
I’ve deleted the link from my original post....perhaps you might do the same kc8 ?
.....Dennis.....
PostPosted: Nov Fri 22, 2019 2:50 am
The late Scott Harvey's (aka Primitiveradiogod) Universal Schematic Locator can be found here...
https://web.archive.org/web/20140122190 ... USL_FILES/
Post New Topic Post Reply  [ 12 posts ]  Moderator: Alan Voorhees
Users browsing this forum: 10.7Megahertz, 1988bluebird, Avery, azenithnut, John Bartley, Mike Toon, wiscojim and 9 guests
