It is currently Oct Mon 25, 2021 3:50 am
 Post subject: Well Pump Replacement Parts
PostPosted: Sep Mon 13, 2021 6:20 pm
I was cruising home from the store the other day (listening to the radio) when I saw this pump sitting out by the curb. couldn't resist and now I have a new project.
I have gone through most of it and it should work when completed but I cannot find a source for the rubber disc valves. does anyone know of a source?
pump is a Rapidayton 300B shallow well double acting piston
the valves are about 3/8" thick rubber discs about 1.5" diameter with a 3/8" hole in the middle
 Post subject: Re: Well Pump Replacement Parts
PostPosted: Sep Mon 13, 2021 7:49 pm
A farm supply store should have what you need.
PostPosted: Sep Mon 13, 2021 8:15 pm
That was worth picking up even if just for the motor.
The lucky ones realize the "Good Ole Days" while they are still in them!
AA5LP
PostPosted: Sep Mon 13, 2021 8:43 pm
I have a very similar piston pump. What I used for the first valves I put in it was rubber laboratory stoppers sliced off to a suitable thickness. They may still be in the pump. A sheet of rubber of the correct thickness can be cut to make valves. It is not too critical, just that the seating surface is flat. The piston seals, on the other hand, are critical. Mine were leather and I have made several sets over the years. The leather disks to make the piston seals should be cut out of dry leather and the circumference skived at an angle so that when the leather seals are soaked in water, softened, and inserted into the bore, the edges form a skirt that is somewhat square with the bore. The smooth side goes against the bore and the seals are cut about 1/2 inch larger in radius than the bore radius. Skive the diameter making the rough side a smaller diameter
Keep in mind, these pumps can only raise water from about 25 feet, but they can make very good pressure.
Mark
PostPosted: Sep Mon 13, 2021 11:12 pm
Thank you for the info, I was hoping there was a supplier for the parts somewhere but searching did not turn up much. Improvisation will commence shortly
PostPosted: Sep Mon 13, 2021 11:16 pm
That appears to be a pretty old unit. The manufacturer may no longer support it, or even be around for that matter.
Sometimes aftermarket parts can be found and lacking that, you make your own.
Paul
...... how hard can it be?
PostPosted: Sep Mon 13, 2021 11:18 pm
it was made by Dayton but they don't appear to sell any parts for it
PostPosted: Sep Tue 14, 2021 7:20 pm
Have a look at McMaster-Carr.
https://www.mcmaster.com/rubber-washers ... washers-6/
The ones I linked to are a little too thin, but you may get by with stacking them.
Mark
PostPosted: Sep Wed 15, 2021 1:21 am
It's going to hard to find good quality rubber. Look into industrial belting too. Not sure what thickness, is it reinforced with cloth? You should be able to make or find something.
only the dead fish go with the flow
PostPosted: Sep Thu 16, 2021 1:31 am
I was in Ace hardware today and they have up to 2.5" rubber fender washers.
PostPosted: Sep Fri 17, 2021 1:04 am
Picked up some just like this from Lowes, have them doubled up. That will suffice for now, if they are not stiff enough I can always add a brass backer to hold them flat.
Post New Topic Post Reply  [ 11 posts ]  Moderator: Alan Voorhees
Users browsing this forum: davep, fifties, OldRelic, paronaram, simplex1040, tubes4life and 21 guests
