It is currently Oct Fri 15, 2021 9:36 pm
 Post subject: Found inside a radio
PostPosted: Sep Mon 13, 2021 8:26 pm
Had a chance to check out the Coronado AM/FM and found a repair invoice stuffed in the corner. Wow! were tubes cheap in 1963. Mind you so was everything else I guess. :D
Gary
Semper ubi sub ubi
 Post subject: Re: Found inside a radio
PostPosted: Sep Mon 13, 2021 8:51 pm
Not only that, if a repair shop had a solid relationship with a wholesale distributor, they were buying those tubes at less than 50% of the suggested retail pricing. The distributor and tube manufacturer were still both making a good profit at that point. I'd expect that the tube manufacturer sold in huge wholesale lots to the distributors at around 15% to 20% of the suggested retail numbers.
PostPosted: Sep Mon 13, 2021 9:08 pm
I also found in one receiver a list of the work that the previous owner did with it. The first record in 1979 and the last one in 1991 - "changed the volume control and put 150kOhm because there was no 100kOhm"
File comment: list
i'm not sad i'm sober
PostPosted: Sep Mon 13, 2021 9:16 pm
Interesting invoice .... three tubes, no other parts, no labour charges. When was the last time any of use had to change two tubes in a radio, never mind three? This leads me to wonder if this was a DIY job and it was the owner who bought and changed the tubes on his own and not a repair shop doing the work.
PostPosted: Sep Mon 13, 2021 9:38 pm
Those prices are retail plus around 10%, purchaser likely bought them from a repair shop.
Sept '63 lists retail for 5Y3 at $1.75, 6BA6 $2.00 & 6AV6 $1.65.
PostPosted: Sep Mon 13, 2021 10:10 pm
I think you hit the nail on the head John, I'm sure the original owner just bought the tubes and replaced them himself. Maybe it needed one of them.
Rest of the radio is original and untouched, no bulging caps etc.. The guy I bought it from said it worked properly and suddenly quit. The line cord is severed where it exits the chassis, so I'm going to replace the line cord and slowly bring it up and see what happens. will recap it anyway no matter what.
Gary
Semper ubi sub ubi
PostPosted: Sep Mon 13, 2021 10:30 pm
I didn't think replacing the line cord would turn into an adventure There are 3 wires in the old line cord and none of the 3 go to chassis ground. One lead goes to pin 5 on the 5Y3GT.
It is crispy and very original looking as where it enters the chassis, there is an insulating plate riveted on that hasn't been disturbed. I didn't take the plug apart, but I imagine 2 of the wires are joined in the plug. Might be time to download a schematic before I go any further as I'm not sure what I'm seeing :oops:
Gary
Semper ubi sub ubi
PostPosted: Sep Mon 13, 2021 10:53 pm
Maybe you’ve got a curtain burner there…….
What is your radio’s model number ?
.....Dennis.....
Live Long and Prosper
PostPosted: Sep Mon 13, 2021 11:01 pm
It's a Gamble Skogmo Coronado 05RA2-43-8515A. I found the schematic and it looks like the third wire is the FM antenna!!! How strange. Pin 5 isn't used on the 5Y3GT. so it's just a solder point for one of the three wire. In the last pic below, you can see the FM antenna wire in middle of the diagonal
opening in the plug.
At the bottom of the schematic there is,... NOTE: "Line cord Antenna wire is not electrically connected to the AC plug terminals"
Mystery solved.
Update: Changed the cord and ran a separate FM antenna wire. Brought it up slowly and it works on Am and Fm is very low, but working. Can't wait to recap it.
Gary
Semper ubi sub ubi
Last edited by Just one more radio on Sep Tue 14, 2021 2:44 am, edited 1 time in total.
PostPosted: Sep Tue 14, 2021 2:40 am
AFAIK no curtain burner ever used a 5Y3...
PostPosted: Sep Tue 14, 2021 3:38 am
Having a third wire in the line cord for an FM antenna was fairly common. So was having a small capacitor connected to one of the line cord wires.
Jim Mueller
PostPosted: Sep Tue 14, 2021 3:48 am
I guess my newbie was showing. I had never seen the antenna wire incorporated into the line cord before. Not a bad idea as it looks much neater than having a separate wire dangling out the back. The original line cord was about 10' long as well. It does have the small cap as well. Was that added to remove noise from the line voltage?
Gary
Semper ubi sub ubi
PostPosted: Sep Tue 14, 2021 9:39 am
The most interesting thing I've discovered inside a piece of electronics gear was a small pair of pliers.
The gear was a silverface Fender Pro Reverb amp with a recurring problem of blowing a resistor in the reverb circuitry. It was easy to diagnose and replace the resistor, but impossible to ascertain the
cause. That is, until while I was putting the chassis back into the cabinet, I happened to notice something move under a mass of wires near the front panel. I fished out the pliers, which were stamped F-11.
I'm certain the pliers had left the factory inside the amp.
PostPosted: Sep Tue 14, 2021 2:47 pm
Found an unused, still-in-the-wrapper condom in a Zenith console I bought from a co-worker. When I asked him he said he hid them there as a teenager so his mother wouldn't find them.
PostPosted: Sep Tue 14, 2021 10:53 pm
NOS 6AV6 tubes are currently selling for $3.
of course a 5Y3GT will make up for that ... even new ones.
PostPosted: Sep Wed 15, 2021 1:28 am
Nobody adjusted the prices of the tubes for inflation.
5Y3 $1.95 in 1963
$17.43 2021 equivalent
6BA6 $2.30 in 1963
$20.56 2021 equivalent
6AV6 $1.90 in 1963
$16.99 2021 equivalent
Grand total (including tax) $57.75
PostPosted: Sep Wed 15, 2021 1:37 am
5Y3 $1.95 in 1963
6BA6 $2.30 in 1963
6AV6 $1.90 in 1963
In that case, tubes haven't really gone up that much. (except the 5Y3's around $40 for an American one.)If my local tube guy had what I needed, it was usually between 10 and 20 bucks. More on line with shipping.
Gary
Semper ubi sub ubi
PostPosted: Sep Wed 15, 2021 5:30 am
Those prices are far higher than now. The 6BA6 is $20 in today's money! Bob at Findatube has NOS 6BA6 tubes for $4.50.
Post New Topic Post Reply  [ 18 posts ]  Moderator: Alan Voorhees
Users browsing this forum: Joezenithman, krystallo, rocketeer, Tarpawns, Tony F and 25 guests
