It is currently Oct Tue 26, 2021 11:37 pm
 Post subject: How to delete a post?
PostPosted: Sep Thu 16, 2021 6:54 pm
Can only see a way to edit.
 Post subject: Re: How to delete a post?
PostPosted: Sep Thu 16, 2021 7:00 pm
You cannot delete a post.
If it bugs you that much, ask a moderator to remove it.
You can change the title of the thread by editing your first post.
Insert something like PLEASE REMOVE and someone will see it.
PostPosted: Sep Thu 16, 2021 7:01 pm
That is correct. Only sysadmin and the mods can delete.
It's not something they do casually and you can expect to have to provide a good reason for doing so.
PostPosted: Sep Thu 16, 2021 7:04 pm
I think that it's a mandatory fine of twenty bucks for a first offense.
:) Greg.
PostPosted: Sep Fri 17, 2021 7:58 am
The few I have wanted to delete a post, I just edit to say, "Self deleted." and maybe say why?
PostPosted: Sep Fri 17, 2021 12:40 pm
You can delete the contents of the original post but not the actual post.
When you delete the original post contents, you can't save the post without some sort of content in the subject field and the text field, like an asterisk or a letter.
Paul
...... how hard can it be?
PostPosted: Sep Fri 17, 2021 1:41 pm
Deleting the contents of the first post in a topic that you have started is a slap in the face to other members who have taken the time to post replies to your topic. It's OK if no one has replied yet.
PostPosted: Sep Fri 17, 2021 1:59 pm
If you decided that you did not want to post on something already running and felt that your was not relevant. You can delete the contents but write delete & perhaps why & if a moderator spots it it will go. If you accidently, or there is a hiccup and a duplicate, you can delete content & write duplicate, either way it is likely to be spotted.
I would agree that common courtesy to responders should apply. You cannot really un-ring a struck bell.
PM to a moderator of the particular category, as suggested is an option.
Marc
PostPosted: Sep Fri 17, 2021 7:18 pm
I started this post because I posted a question, and then found the answer, so I wanted to delete it before anybody replied.
PostPosted: Sep Fri 17, 2021 8:14 pm
In this case, I think it would be better to show your answer.
This would serve the ARF community since posts can live on forever and add to the school of knowledge.
Unless of course the answer was truly embarrassing.
PostPosted: Sep Fri 17, 2021 10:47 pm
Even those are helpful. :wink:
Electronics are filled with smoke. It’s my job to put the smoke back in when they fail.
Cheers,
Jay
PostPosted: Sep Sat 18, 2021 1:27 am
Proverb: Show me a person who has never made a mistake; and I will show you a liar.
We all make mistakes and oversight's, & occasionally say things that we may regret, for its interpretation.
If you have realised you did not explain it well, or post that you found the issue (As noted: Your bad may enlighten another) and post that, the post will die of natural causes & we all move on: Viz "Next item".
Marcc
PostPosted: Sep Sun 19, 2021 12:40 pm
Marcc
So true, Marc. So many different things are discussed here.
Post New Topic Post Reply  [ 13 posts ]  Moderator: Alan Voorhees
Users browsing this forum: 19&41, mblack, Mike Toon, SparkyDan, Spivey, Tarpawns and 17 guests
