| Author |
Bigbopper
Post subject: 1948 Admiral TV - some questions Posted: Nov Thu 11, 2010 2:26 pm |
Joined: Sep Wed 23, 2009 1:31 pm Posts: 24 Location: Near San Diego
Hi all,
I recently purchased a 1948 Admiral console TV, model no. 30A14S. The finish is beyond saving and it needs some veneer work so it will have to be stripped and re-finished. That's not a problem since I have been doing re-finish work for many years. Anyway, here are some questions I hope someone can help me with.
1) Does anyone make a decal set for this Admiral TV?
2) The set is missing an inner knob, where can I find a replacement?
3) The back is missing and I would like to make a replacement but need to know what the original looks like. Anyone have a picture?
Thanks for any help from you experts, Don
| Top |
bandersen
Post subject: Posted: Nov Thu 11, 2010 6:11 pm |
| Member |
Joined: May Fri 29, 2009 3:35 am Posts: 2478 Location: Chicago, IL USA
Hi,
I have several late 40s Admirals including a 30A12 and 30A16 and have been slowly restoring them.
Here are the different finished they used. The 30A12 uses gold decals so I bet the 30A14 does too. The 30A16 uses dark brown decals.
30A12 - Walnut
30A13 - Mahogany
30A14 - Walnut
30A15 - Mahogany
30A16 - Blond
No one makes a decal set as far as I know. Follow this link to see a bunch of photos of a set with intact decals: http://www.videokarma.org/showthread.php?t=248025
You could try this place to have a custom set made: http://www.solidesign.bizland.com/
I believe I have a spare inner knob. I'll shoot you a PM.
The back is masonite and looks like this. I can take some measurements and better photos if you'd like.
| Top |
philsoldradios
Post subject: Re: Posted: Oct Mon 01, 2012 6:43 pm |
| Member |
bandersen wrote: No one makes a decal set as far as I know. Follow this link to see a bunch of photos of a set with intact decals: http://www.videokarma.org/showthread.php?t=248025I'm resurrecting this thread to ask whether anyone has made decals for this TV. I'm refinishing a 24C15 console whose decals look identical (in gold). If someone has already done the artwork, I'd be happy to pay you for copies of those files. My cabinet was so rough that it required stripping, but I preserved the area around the decals and may try blending the new finish in that area. The tricky bit would be matching the new color to the old, of course. If all else fails, I can restrip the front panel and have decals made from my photos of the existing ones. Regards, Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
bandersen
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Tue 02, 2012 8:33 pm |
| Member |
Not that I know of, but I need a few sets too and would be happy to share the costs of getting them made. The original decals on my 30A16 are in very good condition and might make a good start for the artwork.
| Top |
philsoldradios
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Tue 02, 2012 11:42 pm |
| Member |
I know how to do the artwork, but I hate doing that kind of thing and an experienced person could do it 50 times faster. Perhaps some helpful forum member is a whiz with Photoshop or Corel Draw and could turn hi-res close-ups of the decals into cleaned-up two-color images for the decal maker . . . ? An alternative would be to ship photos to the decal guy and let him do the artwork, but that costs more. For the photos you want a close-up of each decal with a ruler next to it. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
noisebox
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 12:57 am |
Joined: Mar Mon 02, 2009 10:48 pm Posts: 2936 Location: Silverton, OR
Phil, I've been a Photoshop nerd for years. I'd be glad to do the artwork just for fun. Those look like one color decals? Both of you guys have been very helpful to me. Consider it a payback. Ben
| Top |
philsoldradios
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 1:51 am |
| Member |
That's very generous. You're right, one-color is correct. Brian's decals are in better shape than mine. His decals also include channel numbers, whereas my set has the numbers on a plastic backplate rather than the cabinet. By coincidence, today I decided to take a shot at refinishing that panel and preserving the decals. The old lacquer was really beat up, with many spots where it was worn or scraped or chipped off. I used solvents to remove most of the old lacquer surrounding the decals. Then I tinted some brushing lacquer, applied it to the newly-bared areas, and let it dry. Then I reflowed the entire panel, including the decals, with a brew of brushing lacquer, thinner, retarder, and a little color. Much to my amazement, it turned out pretty well. This is the first time I've succeeded in reflowing without creating a hopeless mess. The decals don't look perfect -- they were worn to begin with -- but at least, I know it can be done. I'll be happy to send you photos of my decals if you send a PM with your email address. They were all kinda dark and grungy, however, as if someone had slopped stain over that panel in the past. Brian, if you can supply a photo of your decals, that might be easier to work with. Regards, Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
noisebox
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 2:05 am |
PM's with email sent to both of you.
| Top |
philsoldradios
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 3:26 am |
| Member |
Sent email with (grungy) decal pics.
Thanks!
| Top |
bandersen
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 4:24 am |
| Member |
Sure, I'll send some photos of my decals too. Note that although mine are dark brown on this blonde cabinet, I need a couple sets in gold for my other sets including the channel #s. I've had good luck creating decals using water slide decals paper, but don't have the ability to print metallic inks. Thanks! P.S It's Bob not Brian
| Top |
Kevin Kuehn
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 4:45 am |
| Member |
Bob - I can't detect any sign of clear decal film in your 30A16 picture. Is it there and just not visible in the photo, or were the originals possibly dry transfers or maybe even silk screened directly onto the cabinet? Just being curious.
| Top |
philsoldradios
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 5:11 am |
| Member |
The guy at solidesign can print metallic gold. Gets the ink from Germany. He prints as many sets as will fit on an 8.5x11 sheet, so the price per set is reasonable. Sorry about the name. Some days it's an achievement to remember my own name  Phil Nelson
| Top |
bandersen
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 5:17 am |
| Member |
Kevin Kuehn wrote: Bob - I can't detect any sign of clear decal film in your 30A16 picture. Is it there and just not visible in the photo, or were the originals possibly dry transfers or maybe even silk screened directly onto the cabinet? Just being curious. I'm not sure what technique was used originally but I can say that they're buried under the final layers of clear finish. philsoldradios wrote: The guy at solidesign can print metallic gold. Gets the ink from Germany. He prints as many sets as will fit on an 8.5x11 sheet, so the price per set is reasonable. Sorry about the name. Some days it's an achievement to remember my own name  Phil Nelson That's great! I'm also interested in some for the 19A15 7" wooden Admiral. The logo is about 20% smaller than the bigger console sets. Someone stripped mine and coated it in poly  I'm glad your reflowing was successful. That's something I really want to try someday.
| Top |
noisebox
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Fri 05, 2012 4:46 pm |
Got Phil's photos--pretty dark but they'll work. Looks like Brian Bob Banderson's might be better  With both of them I should be able to get it working. I'll be checking my inbox today.
| Top |
bandersen
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 06, 2012 4:19 am |
| Member |
| Top |
M3-SRT8
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 06, 2012 11:20 am |
| Member |
Joined: Nov Thu 08, 2007 1:44 am Posts: 2846 Location: Martha's Vineyard, Mass.
SoliDesign is good. They did a decal sheet in "Aztec Gold" for a DuMont RA-105B I did way back in 2008. He covered the sheet with eight sets of labels. The sheet is solid clear, with the lettering in the color selected. You have to trim them close with a razor blade. I clip the corners of the trimmed decals with a new nail clipper so they don't catch on a finger, and bury them in clear finish. I believe he'll do them in any color you choose, within the color matrix he offers.
_________________ “You can always count on the Americans to do the right thing after they have tried everything else.â€
| Top |
noisebox
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 06, 2012 5:08 pm |
Those look great Bob. Best case scenario is if I can find that typeface for the dial text. If not it's pretty simple stuff--just nit picky. I have a few days off coming up to get it done.
| Top |
noisebox
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 13, 2012 1:21 am |
Made a little progress on the decal graphics this morning. My last days off were spent replacing the timing belt on my car before the rain hit. Tomorrow morning I'll hit it again.
| Top |
Tom Albrecht
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 13, 2012 5:57 am |
| Member |
Joined: Jan Thu 01, 1970 12:00 am Posts: 12186 Location: San Jose, CA USA
Solidesign is a nice find! Unless you guys have any caveats, I'll add them to the supplier list in the Tubes and Parts forum.
_________________ Tom K6VL
| Top |
philsoldradios
Post subject: Re: 1948 Admiral TV - some questions Posted: Oct Sat 13, 2012 5:14 pm |
| Member |
Yes, I was satisfied with the decals that he made for me.
| Top |
