Your horizontal sweep circuit is running at the wrong frequency (roughly 3x the correct frequency). No need to upload a picture; it's a common problem.
If you have the Sams service manual, look for a section about horizontal adjustments. There is often a "coarse" horizontal adjustment in addition to the horizontal hold control. Follow the manual's instructions and see if that improves things.
If you don't have the Sams manual, you can get it directly from the publisher:
https://www.samswebsite.com/en/photofac ... h&s=SearchWhen you say "recapped," I assume you mean replacing electrolytic and paper caps, which is pretty standard in 1950s tube gear. If adjustment doesn't help and your horizontal sweep circuits contain any mica caps, you could also look at the micas. Mica caps are more durable than paper caps, but they fail fairly often in sweep circuits and other applications where they are driven hard.
Regards,
Phil's Old Radios
