Page 1 of 1
[ 6 posts ] |
Author |
mstamper
Post subject: Sony 4-203 external power supply Posted: Oct Sun 27, 2019 7:38 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 308 Location: Windsor, CT USA
I recently restored (recapped) this set. What a job! I assumed that the battery pack delivered 12VDC, so I connected my 2 amp DC power supply to the rear of the set and turned it on. To my amazement, it produced a beautiful picture and sound! My question is: how do I replicate the power supply connection on the side of the set? I have no schematic and can't find one anywhere. I don't know what voltages are expected. There is a 3 prong connector. Is the input 12VDC? 12VAC? 117VAC? What's with the three prongs? Is one a ground? Thanks to all.
Top |
SteveT
Post subject: Re: Sony 4-203 external power supply Posted: Oct Mon 28, 2019 7:02 pm |
Joined: Mar Tue 03, 2009 11:12 pm Posts: 1548 Location: Hutchinson KS
I have one of those sets and a schematic at home, via Sams photofact. Just type in sony 4-203 in your browser and there is a schematic there. It is a weird adaptor!
Top |
mstamper
Post subject: Re: Sony 4-203 external power supply Posted: Oct Mon 28, 2019 11:56 pm |
Tried Sony 4-203. The only schematic that came up was a partial one at radiomuseum. Does your schematic indicate the voltages at the three pins?
Top |
Tim
Post subject: Re: Sony 4-203 external power supply Posted: Oct Tue 29, 2019 4:38 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1804 Location: 07450, New Jersey
This is part of the schematic from Radiomuseum that shows the power supply. 9 "C" cells gives 13.5 volts so the 12 volts you applied was correct. The AC supply is just stepdown transformer and a full wave bridge to provide approx 12 to 13.5 VDC. As you can see, only 2 of the 3 pins are used.
Attachments: |
_________________ Tim
"One of the advantages of being disorderly is that one is constantly making exciting discoveries." A. A. Milne
Top |
mstamper
Post subject: Re: Sony 4-203 external power supply Posted: Oct Tue 29, 2019 3:04 pm |
Thanks! Just what I needed.
Top |
SteveT
Post subject: Re: Sony 4-203 external power supply Posted: Oct Tue 29, 2019 3:55 pm |
mstamper beat me to it! I found the Sams I had which is basically the same except it shows a bit more detail of the various power supply configurations used on this set. The unused pin was used as the ac adapter power to the rechargeable battery, which I have never seen. This is a marvelously overdesigned set for a tiny portable! 34 transistors, 5 tiny rectifier tubes (quintipular?) for high voltage supply. Three sound IF, three video IF, three agc amp stages, etc! And the crt filament is derived from horizontal "pulse" transformer!
Top |
Users browsing this forum: Majestic-12 [Bot], SWR and 5 guests |
