It is currently Jul Sun 12, 2020 1:01 pm
 Post subject: Ballast tube on a Teletone TV-208
PostPosted: Oct Wed 30, 2019 12:06 am
I admit that I'm a total novice when it comes to schematics, so I would appreciate if anyone could answer what is likely a simple question to the skilled.
Here's a PDF of the schematics:
http://www.earlytelevision.org/pdf/tele ... _90-11.pdf
I see on my chassis, what looks to be a ballast tube is marked as "M3" on the tube chart (below the "TOP VIEW" layout)
My question is that if I wanted to replace this part, what exactly do I search for? The one on the set is missing the metal cover, and although the set works okay (it's was previously recapped), it looks rather dicey.
Thank you for any and all info.
 Post subject: Re: Ballast tube on a Teletone TV-208
PostPosted: Oct Wed 30, 2019 12:46 pm
Hi,
Btw., I own the sam set! :roll:
Please check it if it is the same part like in the 7" Motorolas (VT 71/73).
This will be an easy find for spare parts.
If it is the same, here in this forum is a discussion to take an Ersatz
by using resistors.
I am sure there will be a nice guy today going to send this link soon! :idea:
Good luck!
Regards,
SIXMILLION DOLLARMAN
From all the things I ever lost I miss my mind the most
ScottyBeamMeUpThereIsNo 4/3-TV/AM OnEarth
PostPosted: Oct Wed 30, 2019 1:37 pm
SIXMILLION DOLLARMAN wrote:
Hi,
by using resistors.
Good luck!
Regards,
Thanks so much for your response. I have an update - I was able to purchase an NOS metal TBR-104D ballast on the Net and I jumped at the opportunity. The problem is the schematic calls for a TBR-103D. Do you think I'll be okay with this one? I hope so.
PostPosted: Oct Wed 30, 2019 1:55 pm
I don't know if the ballast is the same since it has a different number. I believe that even with the Motorola VT-71, there were variations.
That said, I believe that there were some substitute ballasts made by members here using capacitors instead of resistors. The capacitors did not give off heat as the resistors did.
Question: Wasn't one of the reasons for using a ballast some form of voltage regulation, via nichrome wire?
PostPosted: Oct Wed 30, 2019 2:09 pm
Yes it was.
I just read an old post on Videokarma where a member stated that he thinks the 102D or 104D will work in place of the 103D. I hope he's right, but I will check with my long-time repairman.
PostPosted: Oct Wed 30, 2019 2:21 pm
Fingers crossed for you. I hope it works.
PostPosted: Oct Wed 30, 2019 2:30 pm
Thanks Don. It's a genuine Teletone ballast, so I'm hoping for the best. Finding these seem to be difficult, so I think it was worth taking a shot.
PostPosted: Oct Wed 30, 2019 3:04 pm
Just search for 'The Ballast Tube Handbook', by Jacobi.
The 104/103 are not the same.
PostPosted: Oct Wed 30, 2019 3:17 pm
Thank you very much for confirming that. The seller of the tube wrote me and thought the same thing. He will retract my payment. Oh well, what's in the set now works anyway. Many thanks to you guys!
Post New Topic Post Reply  [ 9 posts ]  Moderators: 7jp4-guy, Mr. Detrola
Users browsing this forum: jhalphen and 7 guests
