It is currently Jun Sat 06, 2020 5:13 am
 Post subject: Is there a TV made by "Cromwell"?
PostPosted: Nov Fri 15, 2019 12:13 am
Seller on FB says they have a Cromwell 12" TV. I can find no reference to Cromwell and my search via pictures has been so far fruitless.
Andy
 Post subject: Re: Is there a TV made by "Cromwell"?
PostPosted: Nov Fri 15, 2019 12:49 am
Yup....same chassis as an Olympic. Craig
PostPosted: Nov Fri 15, 2019 1:21 am
Thanks. Although I'm still coming up blank under the name cromwell, I have found that the Olympic DX214 looks very similar (same knobs and switch layout).
Andy
PostPosted: Nov Fri 15, 2019 2:47 am
Cromwell was a private store brand associated with some retailer of the day. You see a few radios with that name on them, TV's are less common. That doesn't make it rare or valuable though.
PostPosted: Nov Fri 15, 2019 3:40 am
I found the below linked website that indicates the Cromwell was made by Collier & Beale Ltd (in NZ) which had many partner ships including Admiral in the US. Did Olympic us Admiral?
https://www.vintageradio.co.nz/manufacturer/collier_and_beale
Andy
PostPosted: Nov Fri 15, 2019 4:57 pm
Admiral and Olympic each engineered their own different chassis back then and had no association I'm aware of.
PostPosted: Mar Mon 09, 2020 7:27 pm
Sorry to revive an old thread, but it so happens that I'm the one that wound up buying this TV. I've done some research and begun restoration.
This Cromwell set seems to a store-brand based of the Tele-King T712. In case anyone else is in need of that information.
Pic attached. Should work nicely when finished.
Post New Topic Post Reply  [ 7 posts ]  Moderators: 7jp4-guy, Mr. Detrola
