It is currently May Fri 29, 2020 5:02 am
 Post subject: grundig power transformer needed
PostPosted: Feb Mon 17, 2020 8:58 pm
I have a Grundig 5295 Stereo table top radio that is in need of a new power transformer. The part number of the transformer in the unit is 9096-041-04 (best as I can make it out). One primary and 3 secondary windings. filament windings are fine, but I am getting no B+, as a result of no AC voltage coming out to the wires that attach to the rectifier.
Any help appreciated. I think I could use another transformer just for the B+ voltage, so perhaps I don't need the exact replacement for the existing transformer? Thanks,
 Post subject: Re: grundig power transformer needed
PostPosted: Mar Fri 13, 2020 1:35 pm
Hi Noah,
Yes, you're right, another transformer just for the B+ voltage should be okay. I don't think the open winding would cause any problems. The B+ marked in the schematic is 274V 116mA.
Here are the heater requirements, should you want to replace the transformer, as a whole.
6.3 V ~ (with an earthing centre tap) 0.6A for 2 ECC83 tubes.
6.3V ~ 3.635A for the rest of the tubes.
Regards,
Nandu.
https://nandustips.blogspot.com
PostPosted: Mar Wed 18, 2020 9:26 am
Site Admin
Posted in wrong section. Sould beRadio Classified section. Also needs to follow the special rules for posting and ad (Hint: location in profile is required). https://antiqueradios.com/forums/viewto ... 5&t=259925
Post New Topic Post Reply  [ 3 posts ]  Moderators: 7jp4-guy, Mr. Detrola
