At a recent hamfest, I ran across a Panasonic R-1045.
Seller wanted $5 for it, but I declined. -- Never had a chance to look inside.
The cover was on tight and the quarter I was using started to bend. -- Oh noes!
Several hours later, the seller approached me and asked if I was interested.
Yeah, but not at that price point. -- Besides, I never even got to look inside.
He said, "Hey, I don't want to take this home. Will you give me $2 for it?"
Sure... what the heck. -- Can't go wrong for the price of a cheeseburger.
Got it home and thought to open it up. -- But before I did, its evident that
Panasonic made pretty good stuff during that era. -- Nice hefty solid feel.
Had to use a screwdriver just a few inches shy of a pry-bar. -- What a mess inside !
Took out the leaky batteries in hopes there wasn't too much damage.
Ok. - Not bad, but not really good either.
Spent about an hour cleaning and scraping off the corrosion.
Fortunately, it was limited to the battery contacts.
Hardest part was carefully removing the circuit board and speaker.
Well, there's only three (3) capacitors. -- 220ufd, 10ufd and 1ufd.
All came out easily and the new ones went back in smoothly.
Whilst doing some Googling for a possible schematic, I found something interesting.
The Panasonic R-1028 and R-1045 appear to have identical chassis.
Here's a picture from a recent eBay listing:
http://www.ebay.com/itm/PANASONIC-R-102 ... 1085040715
Another interesting observation. -- The speaker in my Panasonic was made in Taiwan,
and the speaker on the eBay listing made in Japan. -- Both radios were made in Japan.
Ernst Erb asked me to make a note of the transistor lineup. -- So here goes.
OSC = 829 - B5? (Plastic case)
1st IF = A105 (Metal)
2nd IF = C829 - C5? (Plastic case)
Audio Driver = 2SB175 (Metal)
Final Output Transistors (2) = 2SB175 (Metal)
Got it back together and it fired right up. -- Plenty of volume for such a small radio.
Sensitivity it top notch for a pocket radio. -- Almost as good as my daily driver.
Will try to log some stations tonite and tomorrow so you can appreciate the performance.
Oh yeah... here's what it looks like after a little bit of work.
~ Mitch ~
