It is currently May Sun 31, 2020 2:19 am
 Post subject: Zenith 1000d Transistors
PostPosted: Feb Thu 13, 2014 2:24 am
Just had a customer drop of his fathers 1000d and it needs transistors as all of them are missing. Does anyone have a list of the ones it needs and a source for them?
 Post subject: Re: Zenith 1000d Transistors
PostPosted: Feb Thu 13, 2014 3:28 am
That sounds very expensive. This might prove to be a cost-saver, shipping included:
http://www.ebay.com/itm/Zenith-Trans-oc ... 417ca7b3a8
There are NTE equivalents for all of them that are acceptable, but they are quite costly. Use the part numbers from the label and punch them in here:
http://nte01.nteinc.com/nte/NTExRefSemi ... f/$$Search
The only real issue is the matched pair output, but they will work OK even if they aren't perfectly matched. You can also use these:
http://www.ebay.com/itm/50-GERMANIUM-PN ... 25850d98fa
for any of the RF or IF positions. They won't work (for long) in the audio section.
But before you go to the trouble of buying something like $60-70 worth of transistors, if you have another 1000 or 3000, might want to temporarily populate the customer radio to see if there might be something else wrong with it.
Brett
PostPosted: Feb Thu 13, 2014 4:20 am
NTE POPULAR GERMANIUM TRANSISTORS
NTE
P/N TYPE APPLICATION
100 PNP Osc. Mixer
101 NPN Osc. Mixer
102 PNP Audio Output
102A PNP Driver, Output
103A NPN Driver, Output
124 NPN Si, HV Power Output
126 PNP RF-IF Amp
160 PNP RF-IF Amp
PostPosted: Feb Thu 13, 2014 5:25 am
NTE
100 PNP Osc. Mixer
101 NPN Osc. Mixer
126 PNP RF-IF Amp
160 PNP RF-IF Amp
Of these, you need the 126, 160, and 102A. I think it might also need 158s, but I will check.
Brett
p.s. apparently, you need (1) NTE126 (or Russian 416p), (4) NTE160 (or Russian 416P), and (4) NTE102A.
PostPosted: Feb Thu 13, 2014 7:11 am
Here is the cross reference chart.
http://www.transistor-repairs.com/zenit ... rence.html
Here is the chart for the 7000
http://www.transistor-repairs.com/R7000.html
PostPosted: Feb Thu 13, 2014 8:43 pm
He said NO!!!!! Far too much. I guess he will take it back or maybe I can get it cheap?
PostPosted: Feb Thu 13, 2014 11:54 pm
Can save some money with the Russian transistors, but there's still the $32 for the audio section. Might be able to find a cheaper Russian sub for those too.
Brett
PostPosted: Feb Fri 14, 2014 12:37 am
I bought it off him for $25 and will replace them as I can
PostPosted: Feb Fri 14, 2014 2:01 am
Wonder how many of the same transistors were used in less popular Zenith sets of the same era ? Have seen a few of the "lunchbox" style sets in rough condition either sell cheaply on Ebay or have listings expire with no interest.
Worth some investigation...
PostPosted: Feb Fri 14, 2014 1:47 pm
Just saw this cheap BIN w/free shipping for a 1000-1 T/O---no pics of inside, though... If it doesn't sell quickly, you could ask for inside views to see if transistors are present...
http://www.ebay.com/itm/ZENITH-Transoce ... 51b9407dee
PostPosted: Feb Sat 15, 2014 1:32 am
Wow, that is a good parts radio.
PostPosted: Feb Sat 15, 2014 5:34 am
I may have a reasonably-priced solution, once again from the Evil Empire. I found a Russian supposed substitute for the 2n2428 used in later TO 1000s for the output. They were $10 for 20 of them+ shipping. This should work as well as the NTE102A as a audio-section substitute.
If so, it looks like you would be able to re-populate 1000/3000 and probably many others for about $8 total, using the 416P for the RF/IF sections and the MP41A for audio. I don't know if Commander McDonald would approve, but we will see if it works soon enough.
Brett
PostPosted: Feb Sat 15, 2014 2:49 pm
They work fine, I have done this many times. I've never repopulated an entire set with them but have had quite a few TOs where some transistors have been pulled and the transistors from a decrepit 755 or similar have restored operation with no I'll effects. I burned one in once for over a week at high volume with a continuous station signal and there was no noticeable performance issues.
While we are on this tack, there doesn't seem to be any reason why transistors from a vintage Japanese transistor radio with germaniums couldn't work as well. There are tons of those out there with are in rough condition but have all the parts that can be had for almost nothing.
PostPosted: Jun Wed 07, 2017 3:37 pm
Do you know the part no.of the Russian equivalent to the nte102 /nte102a?
PostPosted: Jun Wed 07, 2017 9:20 pm
I don't know if they use the same transistors in the TO3000 but here's the equivalents from the service manual....
I'm not sure about going equivalent to equivalent to equivalent and expecting the original good results.
Cheers - Martin ZL2MC
PostPosted: Jun Wed 07, 2017 11:39 pm
Because of this thread I pulled the transistors out of a junk Zenith 710, all with Zenith numbers: 121-147, 121-146, 121-145, 121-53, 121-52, and 121-19. These all seem to cross over just fine to the TOs.
Andy
Post New Topic Post Reply  [ 16 posts ]  Moderator: Dave Doughty
Users browsing this forum: Ken Doyle, Zenith Royal and 5 guests
