It is currently Jul Mon 22, 2019 5:09 pm
 Post subject: Realistic 10 transistor plus TRF radio...
PostPosted: Jan Wed 31, 2018 3:22 am
Hello All,
Found one of these and was wondering if they were as "hot" as was written in a couple articles I found on-line ???
Think I remember where a couple of people here had one.
How is the performance and sound quality ? Imagine they do pretty well being made by Toshiba...
Looks like it might be a later model with the "push down" handle...
 Post subject: Re: Anyone have a Realistic 10 transistor plus TRF radio ???
PostPosted: Jan Wed 31, 2018 4:08 am
Realistic 90L611 appeared in SAMS TSM-46 in 1964
and photofact Set-575 Folder-11 earlier in 1962
PostPosted: Jan Wed 31, 2018 1:05 pm
My uncle bought one when they were first offered. He was a big Yankees fan and needed a radio that could receive a distant station that carried the games. The set did the job but it used a hard-to-find, round 9-volt battery that didn't last very long. Somehow, the radio got lost in his travels. Then some years later, I found one at an estate sale and gave it to him as a birthday present. As I recall, it was a great performer compared to other radios I had at the time. I changed the battery snap connections to accept the more common rectangular 9-volt battery that had become standard. With the newly introduced alkaline versions, playing time was greatly extended. Sound quality was typical of small transistor radios...good enough to listen to ball games.
PostPosted: Feb Thu 01, 2018 1:06 am
Thanks Guys !
Greg---These actually have a readable schematic glued to inside of back cover (found picture on-line).
Dave---Thanks for the story. Bought the one pictured and am sure curious on how it will do compared to my earlier Toshiba 8TM-294 which is an excellent performer without any RF amplification...
Have passed these by for years because I thought the aluminum trim at top looked kinda cheap, but am in "radio withdrawal" after 6+ weeks of not finding any of the few radios left on the "list" and fell to the temptation...
Anyone else have experience with these sets ?
PostPosted: Feb Fri 09, 2018 3:58 am
This radio arrived today---looks much nicer than pictures, but no time to give it a try tonight...
More info tomorrow...
 Post subject: Re: Realistic 10 transistor plus TRF radio...
PostPosted: Feb Sat 10, 2018 2:27 am
Radio fine !
Connected battery with test clips since radio was designed for the old round 9V with different size contacts and turned on---radio worked great with excellent sensitivity, but poor selectivity with adjacent strong stations. ANT & RF trimmers were fine, but "tweaking" IFT's cured problem. This really is a hot little radio all across band and the volume control is noise-free. Plenty of clear audio, but like Dave mentioned, more suited for talk or ball games as it is flat and a bit on the treble side...
Since it works so well with original caps, may just leave it alone since it's in such good cosmetic condition and don't want to crack the fairly stiff leather at the back cover "hinge" area. Just carefully clean it for display.
More to come...
PostPosted: Feb Tue 13, 2018 2:36 am
Gave it a "light" detail cleaning this evening and took a few pics...
Am still debating whether to replace caps as that may improve sound quality even though it does have plenty of volume...
Pics below including one with a Toshiba 8TM-294 of similar vintage...
PostPosted: Feb Tue 13, 2018 6:39 pm
Very nice!
PostPosted: Feb Tue 13, 2018 8:24 pm
^ What Colin said!
Hey John, you might try D/C one end of each Electrolytic at a time, and jumpering it with a new cap, to see if there's any improvement.
If so, and given the newer ones are of course smaller in size, perhaps hollow out the original and restuff it with the newer one. You could probably use either an axial or a radial.
PostPosted: Feb Tue 13, 2018 11:31 pm
Thanks Guys---glad I finally found one of these in good shape within "budget" !
Richard---will probably just use some test leads with mini-clips to jump the caps in audio circuit without removing PCB since radio works so well otherwise. Imagine the audio "tonal" quality is near normal, though, since both Toshiba's sound similar even after replacing all caps...
PostPosted: Jan Sat 12, 2019 10:57 pm
Just got one of these cheap on EPay. Seems to work well as is. W :) :) :) ill be testing it soon...
Apolitical and Agnostic Forever (Well, on the Forum, anyway)! -OZ
PostPosted: Jan Sun 13, 2019 3:03 am
Hey OZ,
Glad you found one !
Decided to leave this one original since it works so well as is and is in such good shape. Really good performer...
Have fun !
Post New Topic Post Reply  [ 12 posts ]  Moderator: Dave Doughty
Users browsing this forum: livewire54 and 5 guests
