It is currently Oct Sun 25, 2020 6:39 pm
 Post subject: Where do you get your transistors
PostPosted: Aug Sun 30, 2020 1:22 pm
I'm new to this hobby. I'm fixing a Emerson 888 Vanguard I've got a bad transistor. The sams on it says RCA 2n408 or Raytheon 2n633. I was hoping someone could point me to a link for a modern replacement.
 Post subject: Re: Where do you get your transistors
PostPosted: Aug Sun 30, 2020 4:16 pm
Those transistors are so old they are collectors items! Haven't been made in 50+ years. You might find something via an NTE distributor, like Newark Electronics.
https://www.primeirow.com/index.php?mai ... _id=364038
https://www.nteinc.com/specs/100to199/pdf/nte102a.pdf
https://www.newark.com/nte-electronics/ ... gKL9_D_BwE
Good luck.
PostPosted: Aug Sun 30, 2020 7:01 pm
Since my local Radio Shack closed, I've bought components from sellers on eBay. There is a seller who has 2-2N408 for sale currently on eBay:
https://www.ebay.com/itm/LOT-OF-2-ETCO- ... Swo-5d-scE
I have also purchased NTE replacement transistors and had good success with them and the replacement for a 2N408 transistor is a NTE102a. Good luck! - Mark
PostPosted: Aug Sun 30, 2020 10:32 pm
For a NTE102A (A=more current capacity), Ive found the Russian GT403G transistors worked fine in the audio output of my TO 3000-1 and the betas were very consistent on my germanium capable tester. However they are big, clunky, and have odd to us pinouts. They may not fit in a tight shirtpocket radio. They are cheap and mine are date coded 1992.
PostPosted: Aug Mon 31, 2020 2:19 am
Whatever transistors you are replacing...
alltransistors.com will list many Equivalent Substitutes - via their... Cross-Reference Search.
https://alltransistors.com/
A Guide to Making Transistor Substitutions.
Bookhttps://www.americanradiohistory.com/BO ... k-1963.pdf
PostPosted: Aug Mon 31, 2020 3:34 am
Me, for subs, I trust two things more than all else - D.A.T.A. manuals, and pre-1998 substitution guides from RCA and ECG. Pre-1998 because of the China dump of questionable transistors (and the later Russian transistors of unknown origin - factory rejects, seconds, remarked, who knows?). YMMV, but I'll stick to known source stuff.
DATA manuals list the transistors in an electrical specification order, meaning you can generally find acceptable subs on the same page (10 lines up, 10 lines down....)
https://archive.org/search.php?query=da ... transistor
ECG replacement Guide - note that NTE bought ECG from Philips, and dumped the quality ECG stuff, opting to procure as they always had.
https://archive.org/details/EcgSemicond ... tGuide1989
As to where I get my transistors for repair, well, I pretty much stocked up back when transistors became passe' - GC, Workman, Motorola HEP, RCA SK, GE, and Raytheon replacement types, and a bunch of bargain bin types at the local distributor, mostly from GC's Calectro line. I added a bunch of MIL-packed stuff when eBay came along, easy enough to cross that 2N408 to a dozen or more part numbers from others, and all nicely NSN coded for searching. I've also got heaps of old boards full of transistors of all kinds, culled from a lifetime of junking stuff.
All too many websites will list a transistor sub that is unobtainable today (and even back then - an in-house development type, or a quickly obsoleted part, for the benefit of a preferred, better, suffixed device (2SC1172 vs 2SC1172B, for example). They list these types not out of malice, but ignorance. And ignorance is far short of authority when it comes to subs.
Brian
PostPosted: Aug Mon 31, 2020 3:51 am
Sorry Greg, but a bone to pick with the Sams sub guide. It ignores Ft of a transistor - completely.
2N2369, a UHF transistor, typically good to over 300MHz operation (I've seen it used as a doubler-amp in 270MHz range stuff). What does Sams sub? A 2N1566A, a transistor that, besides being a physically larger device, tops out with an Ft of just 100MHz or so.
I'm sure there are other "fails" but that one just pops out.
Oh, a disclosure - we sold the Sams library at Cain Electronics back in the 80s. We also had a full file drawer of errata sheets that were to accompany the books when sold. For the transistor specifications (not the sub manual as you listed) it was .....ahem.....38 pages (single sided) of errors, probably 350 or more. Many were simply typos, but a few were transposition with a device on another line or page. Hence my questioning any Sams transistor manual. As WRH has no errata sheets or mention of such......
Brian
PostPosted: Aug Mon 31, 2020 3:58 am
Oh, and germane to the topic of substitutions, there are a couple of the Sony Semiconductor Guides on eBay......cheap. Cheaper than I got mine for, and far cheaper than Sony charged for them. I have no connection to either of the ones listed. The fifth edition is full of good info:
https://www.ebay.com/itm/Sony-Semicondu ... SwrjZa86LL
That'll list the subs for EIAJ 2SA, 2SB, 2SC, 2SD, 2SJ, 2SK, 2SF and other devices, as used by Sony. Typically, they take an older part and list a newer, more contemporary (for the 1980s) part. Same for diodes, chips, and oddball types too.
Again, no affiliation, I don't know the seller(s), but do have a history of using the Sony Guides with success.
Brian
PostPosted: Aug Mon 31, 2020 4:33 am
For your Information Sams Transistor Substitution is searchable.
Visit our site:
I was smokinradios Long time ago (2004)
PostPosted: Aug Mon 31, 2020 2:11 pm
Great. You can search to find an unusable sub. :mrgreen:
Brian
PostPosted: Aug Mon 31, 2020 6:42 pm
I would say most radio repair persons don't need or want to know every detail about a tube. They just get what they need from their stock as a replacement.
You have both ends of the spectrum Perfectionist and businesses or hobbyists that only needs minimum info to get the radio operating.
I remember a guy down at long Beach Naval Shipyard, He was brilliant in electronics, but His downfall was that he analyzed UHF Transceivers circuitry to the point of not being productive to meet Deadlines or to get them repaired and calibrated. (I think He only lasted a year, and He was fired.)
In other words Sam's, in their effort at publishing, has no value? :shock: Or do they use more than one source if necessary?
I guess Sam's just hoodwinked every one! :(
As a leader once said, Trust but Verify!
Visit our site:
PostPosted: Sep Tue 01, 2020 5:56 pm
"...and the later Russian transistors of unknown origin - factory rejects, seconds, remarked, who knows?"
Many of the Russian transistors on eBay are their version of mil-spec, which was comparable to (i.e., lifted from) our mil-spec. Some, but not all of these, can be found with a small Soviet star on them. I have many Nixie tubes with these markings.
I have a feeling that what little "consumer goods" (i.e., transistor radios) the USSR made were built with MIL-SPEC dropouts!
PostPosted: Sep Tue 01, 2020 6:36 pm
Hello Guys,
getting some of these transistors are getting harder and will just get hard ever year and finding IC chips is getting the same way,
Ebay is a good source if you find trustworthy seller that's not selling fake parts .
I have a couple the ECG books also SK and radioshack great source material
PostPosted: Sep Tue 01, 2020 10:34 pm
I bought an old one the other day still sealed in the original pack, dead as a doornail. I hate when that happens.
PostPosted: Sep Sun 06, 2020 3:40 pm
[quote="radiorich"]Hello Guys,
/quote]
I remember in the 70’s that when plastic chip packaging became common(as opposed to ceramic), the thinking was that plastic packaged chips would last only 20-30 years due to moisture migration up the tinned chip legs and into the die. The military would buy only ceramic chips for this reason. This MAY be happening bit it isn’t widespread. I have machines with 100 or so TTL/MOS plastic chips in them from the early 70’s, and I’d say that only 1% went bad.
Post New Topic Post Reply  [ 15 posts ]  Moderator: Dave Doughty
Users browsing this forum: JAYoung and 12 guests
