It is currently Oct Sun 25, 2020 5:01 pm
 Post subject: mitsubishi 6x-300 question
PostPosted: Sep Fri 04, 2020 9:25 pm
So, I am going through some stuff and I ran into this set, thay I got on ebay. It arrived in pieces, the chassis ,antenna, and speaker
were loose, so I set it aside. With all the pieces there, I think I can put it back together, but I need the spots on the board, where the
antenna, and speaker connect.
I did not find a schematic anywhere, so, a chassis picture or two may be my best bet.
Does anyone have this set,?
Thanks in advance, guys.
 Post subject: Re: mitsubishi 6x-300 question
PostPosted: Sep Sat 05, 2020 12:39 am
Hello David.
These Mitsubishi shirt-pocket radios have the same complement of transistors!
https://www.kevinchant.com/uploads/7/1/ ... 6x-145.pdf
https://www.kevinchant.com/uploads/7/1/ ... 6x-148.pdf
PostPosted: Sep Sat 05, 2020 10:58 am
Greg, THANK YOU.! Your depth of knowledge, is greatly appreciated. Stay safe, David.
PostPosted: Sep Fri 11, 2020 9:51 am
Well, the 6X-140 pretty much the same set, and I found all of the connections, that I needed for the
antenna. But, Q 1, which is a 2n219, is open. I did a quick check on the others, and they seemed
to be okay. So, I am going to add that one to my list , and put the radio away for now.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Dave Doughty
Users browsing this forum: EnglishBob and 20 guests
