It is currently Oct Sun 25, 2020 5:20 pm
 Post subject: Aiwa AR-145 break in
PostPosted: Sep Sat 05, 2020 2:54 am
I really want to get in the old radio, clean the contacts, check tuner string rollers, etc. and just take a look but I think the only thing stopping me is this "seal". Anybody have any ideas of how to get past this factory seal? I think it's just 2 screws and this seal and I'm in. This is a good solid old radio, I like it so far, good reception. I want to clean it up, mid 1960's.
 Post subject: Re: Aiwa AR-145 break in
PostPosted: Sep Sat 05, 2020 4:31 am
I would use Channel locks or an adjustable wrench, grasp the 6 sided shaft and rotate it counterclockwise.
PostPosted: Sep Sat 05, 2020 5:01 am
I was trying that earlier but as it loosens on one screw, it would tighten on the other. I was about to pull a Homer and just force it but I backed off. I decided to try and pry it off with a needle pin, it worked, haha, so easy. One of those rare moments when it actually is easier than it looks. I'm getting into old radios more. I have around 100 vintage receivers but getting more into the vintage table radios/clock radios.
PostPosted: Sep Sat 05, 2020 11:58 am
"Factory Sealed for Your Protection".....a classic example of a bit of modern wisdom: Warranties are written to protect the seller, not the buyer.
That widget could have had a different label: "We're discouraging you from trying to do anything inside this set. We don't want you suing us if you wind up damaging the set---or yourself."
But all those words would not fit.......;)
-Mark
Users browsing this forum: No registered users and 16 guests
