It is currently Jan Tue 19, 2021 10:45 am
Post New Topic Post Reply  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: Zenith Royal 500 being purchased
PostPosted: Sep Thu 10, 2020 8:43 pm
IZ5WWB wrote:
Here it is. It looks like a chassis 7XT40Z1.
The volume pot could have been replaced (not sure). The shaft has a threaded hole in the center and looks badly re-worked to make it fit the original knob. The radio receives a local AM station but the audio level is very low.
All in all, not a great deal for 80 euros I think.
https://drive.google.com/drive/folders/ ... sp=sharing
Best regards
Daniele
If it still has the original electrolytic caps, those are nearly universally dead now, which is probably why it has low volume. You can test that by bridging them temporarily, if you don't want to replace the originals (which is what I did in mine). The ones that cause low volume are the two coupling caps, 5mfd, I think, going to the audio driver and to the volume control pot.
I haven't looked carefully at which volume control pot this radio uses, it is possible I have one from a parts radio. If it's the same, and I have one, I will just send it to you.
Give me a day or two to check.
Brett
PostPosted: Sep Thu 10, 2020 9:08 pm
Zenith Royal - I replaced the 121-19 transistor in my 7XT40Z with a Motorola 2N145 and was surprised that it worked quite well, although trying a NTE-102A did nothing. However, the NTE-102A did work as a replacement for the 121-18 transistor. - Mark
PostPosted: Sep Thu 10, 2020 9:16 pm
3Transistors wrote:
As for the volume control, the type used in your Zenith 500 has a 1/8 inch shaft and they are available on eBay. I had to replace the volume control in a Zenith 500H, which has a 1/16 inch shaft and found an affordable substitute after quite a search as there seem to be few switches that would fit. - Mark
Hi Mark, I found on eBay.com exactly the same type of volume pot which is currently mounted on the radio.
https://www.ebay.com/itm/NOS-Vintage-19 ... 3715914493
It is 25 kohms (not a problem), but it has a round shaft, so it would require some metal work to make it flat :roll:
I found not that easy to find an audio potentiometer w/ switch and a 1/8" flat shaft.
BR
Daniele
PostPosted: Sep Thu 10, 2020 9:18 pm
Thanks Mark for sharing your results.
Best regards
Daniele
PostPosted: Sep Thu 10, 2020 9:22 pm
Brett
Thanks a lot Brett for your support.
BR
Daniele
PostPosted: Sep Thu 10, 2020 10:57 pm
Daniele - I found a potentiometer that would probably fit in your Zenith 500, but you would have to cut the shaft:
https://www.ebay.com/itm/One-NOS-NIB-Ph ... Swf-VWZZ25
I made a mistake earlier as the shaft on the Zenith 500H is 1/8 inch and not 1/16 inch. - Mark
PostPosted: Sep Fri 11, 2020 3:13 am
I'm not sure that pot would fit, given it's height.
Daniele, I would suggest messaging the seller of any pot you might want to buy, and ask for it's height, from the back of the switch to the front of the volume control.
PostPosted: Sep Fri 11, 2020 12:00 pm
Thank you, Mark. Unfortunately the item description specifies that this pot has a 1/4" shaft.
BR
Daniele
PostPosted: Sep Fri 11, 2020 11:13 pm
Hello all,
here is the photograph of the volume pot surroundings.
The capacitor pointed by the yellow arrow is the one responsible for the low audio level (3 uF, 6V), I will replace it soon. One of the other three electrolytics had been already replaced (a 100 uF modern capacitor is present in place of the original 50 uF).
The volume pot works fine, but it has a 1/8" shaft, while I have discovered that it should be 1/4", D shape. In fact, an attempt was made to build a "spaghetti" adapter (by wrapping a small piece of steel foil around the top end of the shaft, with the addition of a screw through the center of the knob), which ended up with destroying the knob itself.
Moreover, the pot is not mounted on the chassis by the usual threaded mount. It is soldered to the chassis directly and has no threaded mount at all (quite an unusual kind of potentiometer).
PostPosted: Sep Sat 12, 2020 1:40 am
I decided to get my calipers and measure the potentiometer shaft diameter on my Zenith Royal 500 7XT40Z1 and it was 0.188 inch, the same diameter as on my 7ZT40Z. The overall length of the 7XT40Z1 switch was 1.18 inches, with the switch body 0.47 inch. The potentiometer on the 7XT40Z1 is soldered to the metal chassis, with the switch on the 7ZT40Z1 fastened with a nut. The switch overall length on the 7ZT40Z1 is 1.35 inches.
In order to get my Zenith 500 7XT40Z1 working, you can see that I installed a 10 uf electrolytic capacitor.
Sorry that I probably caused some confusion as the Zenith 500 uses a potentiometer with a 1/8 inch shaft, with the Zenith 500H using a smaller 1/16 inch shaft. - Mark
PostPosted: Sep Sat 12, 2020 8:46 am
Hello Mark, thanks for the scans and figures about the volume pot.
So in my understanding the volume and tuning knobs were not interchangeable on 7XT40Z1, while I supposed they were.
I remember that I read that this changed at some point during the production of the different Royal 500 versions, but I cannot remember where I read this information.
As for the capacitors, I plan to replace the 3 uF with a 10 uF I have. This seems to solve the low audio level issue. Would you suggest to replace the remaining electrolytic caps as well? I tried to connect a 10 uF in parallel with the other old 3uF on the top left corner of the chassis and things got sensibly worse.
Best regards
Daniele
PostPosted: Sep Sat 12, 2020 4:16 pm
Daniele - The tuning knob on the 7XT40Z1 has a 1/16 inch shaft which is round, whereas the volume knob is 1/8 inch. The article below discusses when the Zenith 500 AB was introduced:
http://www.antiqueradio.com/Jul08_MacArthur_Royal.html
My 7XT40Z1 was the first Zenith 500 in my collection and is still the only one that I have with a metal chassis. I only replaced the one electrolytic capacitor to get the Zenith 500 working and it performs quite well. I'm not one to change all the electrolytic capacitors in a vintage transistor radio unless I have to do so in order to get it to work. I used a Zenith 3000-1 daily to listen to the radio with all original components and later switched to a Zenith 900. I bought a GE SuperRadio recently and now use it every day as I have it plugged into the wall and don't need to use batteries. - Mark
PostPosted: Sep Sat 12, 2020 5:57 pm
This is not my case, as on my Royal 500 the tuning capacitor shaft is larger than 1/8" in diameter and has a D shape. I'm certain it is original and the tuning knob matches perfectly with it.
I have just done the same and now the audio level is fully satisfactory (though I have not attempted any re-alignment yet). I agree with you on keeping a working vintage radio as much original as possible.
By chance I also have a GE Superadio on my desk. Great sound!
PostPosted: Sep Sat 12, 2020 6:29 pm
There was another Zenith 500 7XT40Z1 that had the later tuning capacitor:
viewtopic.php?f=4&t=278892
My 7XT40Z1 may have been previously modified as the case is "translucent," but the cover is not.
My GE radio is the later version III, which I bought from a seller on eBay from Southern California who does an excellent job in packaging his radios. The seller uses the most economical means to ship the radio and I don't have a problem waiting. - Mark
Post New Topic Post Reply  [ 34 posts ]  Moderator: Dave Doughty Go to page Previous  1, 2
