It is currently Oct Sun 24, 2021 7:42 am
 Post subject: Value of Delta pocket radio
PostPosted: Aug Mon 30, 2021 11:42 pm
Could anyone help with what the value of this radio would be? I have tried Google with no results, thanks
 Post subject: Re: Value of Delta pocket radio
PostPosted: Aug Tue 31, 2021 1:31 am
Probably around 45$, is there wear markings where the earphone was on the case? does it work?
PostPosted: Aug Tue 31, 2021 3:41 am
I just found it in some old things that belonged to my Grandmother I haven't tried to operate it. What do you mean about the wear marks I didn't notice any but would need to look at it again to be sure...thanks
PostPosted: Aug Tue 31, 2021 5:56 am
dont leave it wrapped like that.
you will get melt marks where the cord touches the case.
PostPosted: Aug Tue 31, 2021 6:56 am
If it's been wrapped like that for all these years, it most likely already has melt marks from the earphone twisted wire. Regardless, they should be unwrapped. If you are going to market it on eBay, a buyer should be able to clearly see the entire front of the case.
According to my 1996 Bunis Transistor guide, it's a three Transistor set, with the value as $80-95.00. That doesn't necessarily mean that it will bring that, it's just an estimate.
I would suggest installing a battery, probably takes a nine volt that you can get at a dollar store, and trying it. If it works, so much the better, but non-operational status is not a deal killer. Having the box adds value to it.
PostPosted: Aug Tue 31, 2021 5:48 pm
Thanks for the information
Post New Topic Post Reply  [ 6 posts ]  Moderator: Dave Doughty
