It is currently Oct Tue 26, 2021 9:13 am
 Post subject: Regency ATC-1 transistor Amateur Radio converter project !
PostPosted: Sep Wed 01, 2021 6:59 pm
Hello All,
This is a historic Regency Division of I.D.E.A., Inc. product, the ATC-1 transistorized Amateur Radio converter. It was the very first device of this type which came out in 1956. Very neat, super-compact, and well-made unit that covers the 80, 40, 20, 15, & 10 meter Ham bands and includes a BFO for CW/SSB & "Q"-multiplier circuit as well as a push-button dial-light activated by tuning knob ! Two transistor circuit (one Philco surface-barrier type). Uses three "AA" pen-light batteries for power. It was designed primarily for mobile operation, but the manual also instructs how to use it with home or portable receivers. It uses the same basic cabinet as the Regency TR-8A (the nearly identical TCR-2 was designed as a "companion" unit for the ATC-1 and came with an installed automotive antenna jack and matching network).
Remember reading about these in old electronics magazines as a kid, but had never seen one in person or even imagined ever owning one ! Two of these appeared on Ebay a few days ago for very reasonable "Buy It Now" prices which included free shipping, so "jumped" on one of them and told another vintage Ham equipment enthusiast friend of mine about the other.
This one just arrived and gave it a quick, careful wipe-down with water-dampened, then dry soft cotton rags. A few dings, dents, scratches, and scrapes, but looks like it will clean up well. Can't wait to try it out with one of my Delco car radios of same time-frame as well as with the TR-8A !
"As arrived" pic below along with ad for the Regency "Tiny Team"...
Regency Tiny-Team 58 Allied catalog p272 7-4-21.jpg [ 562.17 KiB | Viewed 1076 times ]
 Post subject: Re: Regency ATC-1 transistor Amateur Radio converter project
PostPosted: Sep Thu 02, 2021 5:35 am
$79.50, double the price of the whole transistor radio. I wonder how many were sold at that price?
I think I read about the converter sometime before I saw the schematic. Two transistors, so one is a combined mixer and oscillator, the other the BFO. I have no idea how well it works, but that's pretty primitive.
PostPosted: Sep Thu 02, 2021 5:49 am
What do you expect for 1956 electronics? Tubes were still the prominent active elements in most gear.
PostPosted: Sep Fri 03, 2021 5:44 am
Tried it tonight before performing any service. Connected to a 1958 Olds radio on garage workbench. A previous owner had scratched "1430" on lower right corner of battery tray and that is exactly where output was received---unfortunately, there is a strong local at that frequency which came in with it, so will need readjusted. Tuned in several adjacent CW signals on the 40-meter band and sensitivity/selectivity seemed excellent using a few feet of wire as antenna. The power/mode switch is a bit erratic and the pot shaft is very difficult to rotate, but all will be "treated" as needed during refurb. The dial-light even works well and the translucent dial drum looks great when lit !
Definitely an expensive unit for it's time, but is well-made with quality components and was a "ground-breaking" product.
Stay tuned !
PostPosted: Sep Fri 03, 2021 10:45 am
That is a very nice piece indeed. Well done on identifying the unique nature of it and doing what you can to preserve it and make it run again.
There are a number of interesting things like this, from just after the dawn of the transistor revolution. Not everybody notices them and sadly some get lost to the sands of time.
PostPosted: Sep Sat 04, 2021 8:36 pm
Thanks !
Hope to get back to project early next week and post more detail pictures...
PostPosted: Sep Sun 05, 2021 1:00 am
John - With Regency using the same case for their ATC-1 as the TR-8A reminds me of someone using the Sylvania Thunderbird transistor radio case for intercoms. - Mark
PostPosted: Sep Sun 05, 2021 1:16 am
This very interesting...
Though not for Ham I have a at least one of those "Police" converters that converted the local HF police signals to BC band. The converter was keeps next to the transistor radio for reception of the police calls.
Now police have moved to VHF and gone scramble so it is a useless device. None the less When I am on the prowl I will look for some of this kind of general coverage converter.
Thanks Chas
PostPosted: Sep Sun 05, 2021 4:34 am
Just for fun, took a picture of the ATC-1 in front of an NC300 of same vintage that I detail cleaned exterior yesterday to sell to a friend of mine...
PostPosted: Sep Sun 05, 2021 4:48 am
There were those Tomkins Tuneaverters. A small company, I don't think they sold much else. But in business for maybe a decade, advertising in multiple magazines. I guess they weren't more than a combined mixer/oscillator, either. All.meant to feed into a car radio, there were models for shortwave, police band, CB. Some came with a BFO, others had the option of a crystal controlled channel.
I remember pictures in the magazines where people used them at home.
PostPosted: Sep Tue 07, 2021 11:43 am
Very interesting find.
PostPosted: Sep Sat 11, 2021 12:50 am
Thanks Guys...
Completed this great little unit today !
Disassembled and detail cleaned inside & out. Used Q-tips and cold dish-soap solution on front panel being very careful and gentle around the silk-screened graphics---took some time to get clean. Polished the dial window inside and out carefully with Novus-2 after cleaning. Pressed out what I could of the dent on top left from inside with flat tip of screwdriver. The knobs required a lot of scrubbing with "stubby" toothbrush being very careful around the white painted indicator line---used Mothers California Gold carnauba wax with Q-tips on the "brights".
Applied a tiny amount of synthetic oil to base of BFO/Q-MULT pot shaft which was binding---after working it back & forth several times, it now rotates smoothly as it should. Very carefully applied DeOxit Gold liquid with "trusty hatpin" to all switch contacts---entered the 3-position "mode" switch through the small openings around circumference.
Loosened setscrew slightly on band-switch pulley to adjust position of dial drum in "window" as recommended in manual. Pointer was rubbing drum, so carefully bent it into proper position. Cleaned drum very gently with water-dampened followed by dry soft pieces of paper towel. Reseated transistors. Carefully blew out with compressed air before reassembly.
Made a "proper" J3 jumper plug out of RCA connector. Also made a patch cable long enough to connect to car radio from an old Delco car antenna line. Followed the manual to reset the output frequency to 1290 using my "built-in" Delco ETR in garage as receiver. Followed the set-up alignment procedure and it now seems to work very well on all bands although there was very little to hear...
Was thinking how close Regency was to building a compact transistor multi-band receiver ! Wonder if they ever considered it ??? If they'd expanded the frequency coverages, added an RF-amp as well as the the AM broadcast band, and coupled this in a slightly larger cabinet with the TR-8A IF & audio stages, think they would have had a "winner" !
Project pics below in two "installments"---please "click" on images for larger views ! Converted last picture to monochrome to show the "new Tiny-Team"... Unit definitely has wear & "character" from use, but did clean up pretty well...
PostPosted: Sep Sat 11, 2021 12:52 am
Here are the remainder of pics---please see previous post for first installment...
PostPosted: Sep Sat 18, 2021 1:50 am
I own the hand built prototype ATC-1, made by Tex Toler
PostPosted: Sep Sat 18, 2021 3:38 am
That’s great, Bill—-would sure love to see some pictures !!!
PostPosted: Sep Sat 18, 2021 9:16 pm
Bill, I'd love to see that prototype as well!
Nice work on restoring your ATC-1, John! It seems you got a great deal on it too. Did you have to make any adjustments to the alignment?
I have two of these converters, but neither of them pulled in any stations last time I tried them (years ago). I'll have to take another crack at getting at least one of them working at some point.
It's possible I just wasn't checking the right bands at the right time, or my wire antenna was insufficient. It does at least look cool on display at least.
PostPosted: Sep Sat 18, 2021 9:40 pm
Thanks much, Matt !
I performed the output frequency adjustment to a quiet spot within recommended range on AM BCB and did the "set-up" alignment as described in the manual (which was a free download) and it did appear to work on all bands, but very little received even with a good antenna. You could hear a peak in the background noise level using the antenna trim adjustment, but only heard a couple stronger signals. There is no RF-amp stage, so really wasn't surprised as tuning the ranges on my GE P-4990 (which was handiest multi-band receiver at the time) also yielded few signals. After reading through the manual, am thinking I'll have to realign all bands after shifting the output frequency, but think I'll wait until I get a better RF signal generator...
Hope Bill posts pics of his prototype soon !
PostPosted: Oct Sun 10, 2021 1:13 am
Here's the prototype made by Tex Toler, compared side by side to a production model.
PostPosted: Oct Sun 10, 2021 1:15 am
And here's the tiny team package, made by Toler as well, perfect for a field day outing. Complete with ARRL log book and antenna switchbox.
PostPosted: Oct Sun 10, 2021 5:03 pm
Thanks very much, Bill—-can’t wait to see pics on large screen when able !!! Very neat story yesterday at meet.
Post New Topic Post Reply  [ 22 posts ]  Moderator: Dave Doughty Go to page 1, 2  Next
