It is currently Oct Tue 19, 2021 6:16 am
 Post subject: German radios
PostPosted: Sep Sun 19, 2021 2:08 am
Hello all,
A friend of mine who is a Ham radio operator out west was wondering if I could get his Telefunken Kavalier working for him. It's a german radio with SW, FM, and AM. Here's the radio museum link- https://www.radiomuseum.org/r/telefunke ... _3291.html
He tried it on all the bands and he said it just makes a crackle when turned on. My guess was a bad electrolytic in the output stage.
My question is, Are these german radios difficult to work on? This model looks like it has multiple circuit boards.
Would like to hear from others who have worked on this set in the past.
Thank you,
Henry
 Post subject: Re: German radios
PostPosted: Sep Sun 19, 2021 6:52 am
Hi Henry!
All German radios of those years are similar and nothing complicated. Naturally, they need cleaning, replacement of electrolytic capacitors and alignment. You has to be careful with gentle gemanium transistors only.
I recently renovated a similar radio
https://antiqueradios.com/forums/viewtopic.php?f=4&t=401450
i'm not sad i'm sober
PostPosted: Sep Sun 19, 2021 7:43 pm
Thanks, Vlad!
PostPosted: Oct Wed 06, 2021 5:37 am
If it has any AF117 transistors in it that may explain why it's dead, those like to develop tin whiskers inside the can, which cause them to short. You can either remove the whiskers (there is a procedure for this) or substitute the AF117s with a Soviet substitute.
Regards
Arran
PostPosted: Oct Wed 06, 2021 7:23 am
Regards
Arran
Also a bit of a problem. In a GrĂ¼ndig C4500, which is of no value, but great for a background in a garage (also surprisingly good on SW), I changed the original transistors (10 euros for pair) for Soviet Đ“Đ¢402/404 (0.7 euros). Ugly, but works.
File comment: AC187
File comment: GT402
File comment: new
File comment: C4500
