It is currently Jun Thu 30, 2022 1:17 am
 Post subject: Silver plated coax connectors
PostPosted: May Sun 15, 2022 4:16 pm
I have received a LOT of coax antenna connectors that are silver and are tarnished, some badly. Do they need to be polished or is the plating conductive even if tarnished? Carl
Honey, I must go to the store for a loaf of toast. We're out again.
AB1ZI
 Post subject: Re: Silver plated coax connectors
PostPosted: May Sun 15, 2022 4:46 pm
For any significant power level the resistance of the tarnish is insignificant.
Dale H. Cook, Retired AM/FM/TV Chief Engineer, Roanoke/Lynchburg, VA
https://plymouthcolony.net/starcityeng/index.html
PostPosted: May Sun 15, 2022 9:04 pm
Thank you Dale.
AB1ZI
PostPosted: May Sun 15, 2022 10:28 pm
Greetings to Cwebs and the Forum:
It depends on the tarnish. Most tarnish is silver oxide, which is just about as conductive as the pure metal and so is not a problem. Silver sulfides, however, are another kettle of fish entirely. Exposure of silver to air pollution (which often contains significant amounts of sulfuric acid) will create corrosion that is non-conductive and will seriously interfere with the connector's performance.
Jim T.
KB6GM
PostPosted: May Sun 15, 2022 11:00 pm
How best to remove it?
PostPosted: May Sun 15, 2022 11:16 pm
Tarnish (black) is generally silver sulfide, not silver oxide (which is white or gray). SIlver sulfide is not a good conductor.
PostPosted: May Sun 15, 2022 11:20 pm
Thankfully my tarnish is gray.
AB1ZI
PostPosted: May Sun 15, 2022 11:47 pm
Because coaxial connector are silver plated you should not use common silver polishes. Some contain an abrasive which is suitable for sterling but will reduce the thickness of silver plating. Others make the silver sulfide soluble which also reduces the thickness of the plating. A mixture of 1 cup of baking soda to 1 gallon of boiling water poured into an aluminum foil lined pan will do the trick by chemically detaching the sulfide radicals from the silver. Although some of the sulfide radicals remain in solution most of them will bond with the aluminum foil. Cleaning should be followed with a thorough rinsing.
I have used this for silver-plated tablewear, but I don't think I would use it for most coaxial connectors. I have used it for GR 874 connectors because I have a GR-874TOK toolkit for disassembling and reassembling the 874 series, letting me subject only the plated parts to cleaning.
PostPosted: May Sun 15, 2022 11:57 pm
Personally, I would think that since the usual coax connector contact surfaces are sliding contacts (center pins, threads, bayonet twist locks) the tarnish probably gets wiped from the contacting surfaces. I have not studied that, however.
PostPosted: May Mon 16, 2022 1:17 am
I have thought that wiping might help, but have not studied it.
PostPosted: May Mon 16, 2022 6:44 pm
Get a bottle of Tarn-X. It removes silver tarnish very well and quickly.
PostPosted: May Mon 16, 2022 9:50 pm
By removing the tarnish Tarn-X also removes some of the plating by dissolving and removing the silver sulfide. The only satisfactory way to remove silver sulfide tarnish is to reverse the chemical reaction that created the tarnish with another chemical reaction that detaches the sulfide radicals from the silver atoms. That leaves the original silver plating intact.
PostPosted: May Tue 17, 2022 2:04 am
A pencil eraser works well to clean silver tarnish (grey). But if it is grey I wouldn't worry about it. I only clean where it needs to be soldered. As noted, it is almost as good a conductor. Just use 'em and be happy.
PostPosted: May Tue 17, 2022 5:50 am
I thought it was supposed to be washing soda that you put in the water with the aluminum foil, not baking soda. ?
WB6NVH
http://www.wb6nvh.com
PostPosted: May Tue 17, 2022 1:03 pm
It is baking soda (sodium bicarbonate) which should be used because it is a milder alkali than washing soda (sodium carbonate).
PostPosted: May Tue 17, 2022 1:10 pm
All good info, Thanks guys, Carl
AB1ZI
PostPosted: May Tue 17, 2022 2:52 pm
They’ll be fine just like they are. Don’t sweat the tarnish.
PostPosted: May Tue 17, 2022 5:15 pm
nothing more than a slight amount of Dexoit on the RF current bearing surfaces.. other than that, do not sweat it. it can be an IMD issue in some unique repeater applications. I would not use any chemicals that result in conductive leakage paths!!!!
PostPosted: May Wed 18, 2022 4:49 am
The correct approach is to replace the connector. If any sort of cleaning solution gets into the cable itself, you will be worse off than you were to start.
Jim T.
KB6GM
PostPosted: May Wed 18, 2022 12:19 pm
In post #1 the OP said he came upon lots of coax connectors, not cables.
But never mentioned the style of connector, or application he had in mind for their usage.
Post New Topic Post Reply  [ 21 posts ]  Moderator: Sandy Go to page 1, 2  Next
Users browsing this forum: Jthorusen and 7 guests
