It is currently Sep Sat 26, 2020 12:39 pm
 Post subject: Ohmite D-101?
PostPosted: Mar Mon 18, 2019 3:22 am
I've run up on an Ohmite D-101 100 watt dummy antenna 600 ohms, because I need something to work on my Knightkit T-60 transmitter. But if the dummy load is 600 ohms, what good is it? For what purpose would a 600 ohm dummy antenna be made?
 Post subject: Re: Ohmite D-101?
PostPosted: Mar Mon 18, 2019 4:01 am
How old does it appear to be? In the 1930s 600 ohm open-air transmission lines were pretty common for radio amateurs, so they could use a 600 ohm dummy for transmitter tune-up and testing.
PostPosted: Mar Mon 18, 2019 4:27 am
Thanks. You answered my question and it's all I need to know. I can't use it. It's on ebay right now for 4 or 5 dollars.
PostPosted: Mar Mon 18, 2019 6:50 am
Is it in a can?
Visit our site:
PostPosted: Mar Mon 18, 2019 8:25 am
600 ohms is standard impedance for audio systems.
Your item is a dummy load, but not a dummy "antenna".
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Mar Mon 18, 2019 9:09 am
I have found pictures of D-100 clearly marked DUMMY ANTENNA RESISTOR at 73 and 146 ohms. I have not seen one for 600 ohms.
PostPosted: Mar Mon 18, 2019 1:26 pm
kb3wbb
PostPosted: Mar Mon 18, 2019 2:21 pm
Leigh wrote:
henry finley wrote:
F600 ohms is standard impedance for audio systems.
Leigh - After almost 50 years of working with 600 ohm audio lines I have never seen one that would need a 100 watt dummy. Whether they be studio audio lines or telephone lines their power is measured in milliwatts, unlike 70 volt or 100 volt speaker lines. I would note also, after nearly 50 years of working in broadcasting, that a number of transmission line standards were used in the decades preceding the development of coaxial lines.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Sandy
Users browsing this forum: Google [Bot], mrrstrat, N4NYY and 9 guests
