It is currently Feb Sat 29, 2020 2:04 pm
 Post subject: Hallicrafters S40A Antenna Question
PostPosted: Dec Wed 05, 2018 1:52 am
Hello,
I'm having trouble finding the antenna input impedance for my Hallicrafters S40A. Anyone happen to know this offhand or know of a resource for finding it? Thanks for any help.
Karl
 Post subject: Re: Hallicrafters S40A Antenna Question
PostPosted: Dec Wed 05, 2018 2:47 am
It is my understanding that since your receiver works on so many frequencies the input impedance would not be constant. I would just experiment with different antennas an find the one that works best for your set.
Knowledge is useless unless you can share it. KA5OBI
PostPosted: Dec Wed 05, 2018 2:49 am
That front end is pretty broad at 50 to 600 ohms impedance. Performance really depends on the antenna and it's resonance.
Typically, if you are going with unbalanced line (i.e. 50 ohm coax), connect the inner conductor to # 1 and the outer shield to # 2. Ground # 2 to the ground terminal (jumper). Otherwise, balanced line (i.e. 300/400 ohm etc) to 1 and 2 with no jumper. Single wire typically to #1 with a ground to 2.
Depending on what you are using for an antenna and the band you are choosing, variations on the above (i.e. no jumper from 2 to ground with 50 ohm coax) may prove to be better....
Todd
ka8gef
'Itoshiki oshieo idaki'
-Let us never lose the lessons we have learned.
PostPosted: Dec Wed 05, 2018 2:54 am
Karl,
The input impedance of the S40A (and pretty much all classic communications receivers) will vary wildly across its coverage range. generally the target range was around 70-400 ohms so it isn't critical. Your S-40A will be happy fed with a long wire, coax, twin lead, etc. Most antenna connections will require shorting terminal A2 to ground, if using a balanced feed connect it to the A1 and A2 terminals with the short from A2 to ground removed, otherwise (for coax, single random wire, etc.) connect the "hot" lead to A1 and short A2 to ground.
Especially for receivers like the S-40 series where there is no antenna "trimmer" or compensator the best alignment of the input coils occurs with the antenna connected during alignment with the signal generator lightly coupled to it.
And on edit, I see Tod already addressed your question :)
PostPosted: Dec Thu 06, 2018 4:02 pm
Thanks folks. New antenna is inbound. I had to go with a powered loop due to my location. I'm still trying to work out the best longwire solution, but that may have to wait until the summer at this point.
Karl
Post New Topic Post Reply  [ 5 posts ]  Moderator: Sandy
Users browsing this forum: rsingl and 7 guests
