It is currently Oct Wed 27, 2021 5:23 am
Post New Topic Post Reply  [ 112 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Show off your vintage station!!!
PostPosted: Dec Mon 07, 2020 4:53 pm
Big Black Screen ????
73 es HH, Dick, W1KSZ
PostPosted: Dec Mon 07, 2020 5:39 pm
I figured it is a “blank slate” upon which his future station would be created.
Then again, I was wrong already once this year.
73, de Chuck K4CCW
PostPosted: Dec Mon 07, 2020 6:15 pm
My vintage station.Only modern item not pictured is Kenwood VHF/UHF dual bander. I need to install the radio table.
PostPosted: Dec Mon 07, 2020 10:06 pm
Wow some mighty fine stations you all have! :D
Be happy ,enjoy life as its so short!
PostPosted: Dec Mon 07, 2020 10:23 pm
Some of the operating positions. ALWAYS a work in progress :)
Rodger WQ9E
PostPosted: Dec Tue 08, 2020 1:11 am
Ham shack main operating position on the rare occasion that it was clean enough to photograph:
Novice Rig Roundup operating position; this is a duplicate of my ham station in 1963, novice call WV6WAM. The Ranger and HQ-129 are the same models but unfortunately not my original radios from 1963. The keyer is newer also; used to provide side tone (didn't have side tone in 1963, probably had terrible fist). The cheap plastic straight key on the scrap wood base is the only thing that has survived from my original novice station:
Original Novice License; the canceled one reflects a change of address:
Regards,
Jim T.
KB6GM
PostPosted: Dec Tue 08, 2020 1:51 am
Love the cancelled novice ticket.
I used to have all of my old licenses. When I moved from my parents house to mine I had them in a box in the basement not thinking the basement would flood in bad rain storms. Needless to say many things succumbed the first time the basement flooded - over 12" of water in it. Had drains put in very shortly thereafter but many things were lost including many early shack / antenna pictures, QSL's and my first licenses / renewals.
W3TA
PostPosted: Dec Tue 08, 2020 5:10 am
Hi Jim,
Nice looking V-II and R388. Nice looking NCX-5 too, I guess thats the power supply setting under the chair. When is your bench going to be done?
Hi Rodger, many very nice radios I don't think you posted here before.
That Hallicrafter's "desk" is pretty nice, and I also noticed your EFJ desk, with a 500 setting on it. That's not complete, the Thunderbolt is missing! You've got a very nice collection. Thanks for the pics.
The EFJ Desks are nice, and only about 400 were built, from 55 through 57, and a bit more than twice that number of 500s were built from 57 to 64. We just had two Desks in here about 3 weeks ago. One in operating condition and the other was complete, but a work in progress. They didn't stay long, a old customer came in and bought them both.
I've wanted a 500 for years, and got one in fairly nice condition just a few weeks ago.
Hello Jim, nice S-line radios, look to be all be Bat wings. Your HQ-129 looks especially clean and I like what appears to be a "leatherman" quick change crystal swapper. :wink:
PostPosted: Dec Tue 08, 2020 8:41 am
Greetings to Mike and the Forum:
<snip> I like what appears to be a "leatherman" quick change crystal swapper. :wink:
Got it in one! :D
73,
Jim T.
KB6GM
PostPosted: Dec Tue 08, 2020 2:09 pm
Hi Mike,
I have a Thunderbolt set up with a Pacemaker. Like the Hallicrafters HT-33, that is one heavy and awkward to move amplifier. Of course the same goes for the Viking 500 external power supply/modulator whose center of gravity is higher than the otherwise handy side handles. Don't break a wrist when it tries to flip on you.
If you use the built in slow release relay in the 500 to control the antenna relay, realize that the residual magnetism effect that creates the slow release doesn't age well and you may find it "hot" switching. That was the issue with mine. Attached is the simple cure and with that in place the oft maligned interconnecting cables are fine, they do NOT arc under the normal voltage levels that occur in a properly operating 500 and if they do arc then something is amiss and better to have the arcing at the cable connectors than upgrading those and having the arc take out something far more expensive.
And on edit Mike, attached is a photo of the Tbolt/Pacemaker setup and some other stuff.
Rodger WQ9E
Delay relay 500.pdf [7.85 KiB]
Downloaded 62 times
PostPosted: Dec Wed 09, 2020 9:51 pm
Here is my humble station, I think it qualifies as vintage.
KS4KP, Jeff.
Jeff
“Nothin’s worth nothin ‘till somebody wants it.”—Irv Metter
PostPosted: Dec Wed 09, 2020 10:35 pm
Not my station. But wow, this kid is doing great with a few watts on cw...he’s got qsls from Chile and Japan!
PostPosted: Dec Wed 09, 2020 11:57 pm
The Icoms are interesting! oddly enough, I've never owned a single piece of Icom gear.
Always Yaesu, Kenwood or other brands like Alinco.
PostPosted: Dec Thu 10, 2020 1:20 am
These are the earliest Icom pieces I own, they were still using the founder's name at that point before Inoue Communications was shortened to Icom.
The 700R receiver is completely solid state, the 700T transmitter uses two 12BY7A tubes as a mixer and the driver with S-2001 (6146B) finals. The IC-2K amplifier uses a pair of 572B tubes for its rated 1,200 watts input.
The 700T transmitter doesn't have its own VFO and is primarily intended to operate as a transceiver. This was a common approach with much of the early Japanese SSB separates including the Yaesu FL/FR-50 twins and the Trio 310 twins which used either the receiver, a crystal, or an external VFO for the transmitter frequency control.
Rodger WQ9E
PostPosted: Dec Thu 10, 2020 2:05 am
KS4KP, Jeff.
I like it - I especially like seeing that the paddle on the bug looks well worn!
W3TA
PostPosted: Dec Thu 10, 2020 5:16 am
Rodger WQ9E
The National NCX-5 is a great transceiver.
PostPosted: Dec Fri 11, 2020 11:48 am
russian antique radio club: http://rf.kievrus.com/index.php
PostPosted: Dec Fri 11, 2020 8:23 pm
Great photo! Neat looking radios and a fine young ham operator. :D
KE5YTV
PostPosted: Dec Fri 11, 2020 8:40 pm
Love the photo Well!
Rodger WQ9E
PostPosted: Dec Sat 12, 2020 1:36 am
Photo not showing up for me............?
W3TA
Post New Topic Post Reply  [ 112 posts ]  Moderator: Sandy Go to page Previous  1, 2, 3, 4, 5, 6  Next
