It is currently Jan Sat 16, 2021 1:22 am
Post New Topic Post Reply  [ 102 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Hallicrafters S-11 project
PostPosted: Nov Fri 20, 2020 2:13 am
Interesting experiment tonight - a 6J5 has the same basing as a 6C5, and is similar characteristics,
except a higher transconductance by a bit. So I substituted one of those in place of the stock osc.
tube.
The oscillator now runs on the high band, over about half (lower half) of the dial. So no wiring error,
something is possibly low Q as mentioned above, or the 6C5 I'm using (well, both of them that I tried)
is a bit of a dud.
At the upper range of its operation the oscillator can be more or less killed by touching the coil.
PostPosted: Nov Mon 23, 2020 7:57 pm
The top band can be aligned now, up to around 30 MHz. I think I will leave the 6J5 in there.
Is there any spec on how much signal is supposed to be on the grid of the 6L7 mixer? On the lower
bands it's very high.
PostPosted: Nov Tue 24, 2020 8:58 pm
Possibly it's time to re-wind the coil for that top band. It's phenolic right now, and that apparently has a pretty bad loss tangent. My go-to material would be teflon I suspect.
PostPosted: Nov Wed 25, 2020 12:57 am
One of my favorites, I've done a couple of those. Great performers with unmatched audio into an adequte loudspeaker. Push pull 6l6s man! Here's a couple I've done
http://hillamplification.com
PostPosted: Nov Wed 25, 2020 2:28 pm
Hmm. Those brass thumbscrews look oddly familiar.
Also - yours is missing the pointers on the knobs, like mine. Honestly I think that looks nicer that way.
PostPosted: Nov Wed 25, 2020 3:33 pm
Was that you that turned those thumb screw for me Jim. It was 20yrs ago so? Yea those pointers get brittle and dont last sometimes.
PostPosted: Nov Wed 25, 2020 5:16 pm
Brian your sets look great. You guys are inspiring me to dig mine out and get to work.
KE5YTV
PostPosted: Nov Wed 25, 2020 7:11 pm
Yep, was me. Did I sent a print with those? Seems like, I need a few more now!
PostPosted: Nov Wed 25, 2020 8:58 pm
Right on, Thanks again. You can get them online and even ACE I found some once. Here's Home Depot. https://www.homedepot.com/p/Everbilt-10 ... /203537783
PostPosted: Nov Mon 30, 2020 6:59 pm
Band 5 oscillator: still not working correctly, apparently. So I removed the oscillator coil to see what's up.
Here's what it looks like:
PostPosted: Nov Mon 30, 2020 7:01 pm
And here is what the space where it was, inside the set. The 100 pf capacitor indicated on the photo, is marked as 100pf
and is listed on the schematic as 100 pf. When measured it's really only 50 pF or a little less. So this needs to be replaced while
I am in there.
PostPosted: Nov Mon 30, 2020 7:03 pm
In the meantime the main idea was to produce a similar coil using low loss materials. I chose teflon for the coil
form and for the wire insulation. First step was to draw what I needed to build.
PostPosted: Nov Mon 30, 2020 7:05 pm
Next was to fabricate the teflon form to match the phenolic original. Rather than make the copper right
angle brackets from scratch, I stole a few from the parts set I have on hand.
PostPosted: Nov Mon 30, 2020 7:07 pm
The brackets in the original coil are held on with hollow brass rivets, which I could not source. So I manufactured them, out of brass rod.
This is a small instrument makers lathe that I use for parts like this.
PostPosted: Nov Mon 30, 2020 7:10 pm
It was a bit tricky to assemble it all but in the end it came out OK. The coil was then wound with solid wire as the original
was done, but using the same size teflon tubing as insulation as the original insulation, to keep the spacing correct. The
terminals were too complicated to copy so I used stake-in pins instead.
PostPosted: Dec Tue 01, 2020 1:36 am
Mica capacitors are causing some problems now. I was just about to suggest checking them, but you beat me to it. On testing old micas, I have found some like yours, which were off value.
PostPosted: Dec Tue 01, 2020 2:00 pm
Good job.
PostPosted: Dec Tue 01, 2020 4:17 pm
The top band (5) works now, over the entire range. Although putting a scope probe on the osc. grid will cause it to quit about
2/3 of the way up. The alignment is a bit dodgy but then it probably always was. I might try adding a some trim to bring it closer.
Paint for the cover is proceeding at all due speed!
PostPosted: Dec Tue 08, 2020 6:50 pm
And "after" photos of the cover paint job. It's missing the brass thumbscrews at the moment, which are in the works:
PostPosted: Dec Wed 09, 2020 3:31 am
Your black wrinkle looks great. Did you use a heat gun or oven?
KE5YTV
Post New Topic Post Reply  [ 102 posts ]  Moderator: Sandy Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Als_Basement, hwhall, Majestic-12 [Bot], Phil Coe, Steve423 and 13 guests
