Author |
mrrstrat
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 4:22 pm |
Member |
Joined: May Wed 20, 2020 1:33 am Posts: 311 Location: Rockford, IL
This thread is great - like a lot of others I am struggling with the "One Antenna to rule them all" solution. I have looked at building or buying a tuner - one thing I like about my SX-110 is that the antenna tuner makes a HUGE difference when I switch bands. I am thinking I would like one I use in general but I don't wanna build something that looks like a Gilligans Island device nor shell out $250 for one. Is there a good and simple design for a antenna balancer that sits between the set and the wire antenna? I see a few designs but they look like for transmission. I am strictly receive on my listening sets and just want something like my SX-110 has for all of my sets. Any ideas?? CLEG wrote: i am using a rain gutter its about 70 feet total i have a wire connected too it that go/s though the window of my basement apartment it go/s into an amp supply ant tuner works great on 40 meters and other bands i am not allowed a wire ant so this is a hidden ant its the only way i can stay active as a ham Greg
Top |
jimbenedict
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 5:57 pm |
Joined: Jan Tue 07, 2020 1:41 am Posts: 3567 Location: Fenton, MI 48430
[quote="mrrstrat"]This thread is great - like a lot of others I am struggling with the "One Antenna to rule them all" solution.
Any ideas??/quote] MFJ 956 antenna tuner is about $80 new. $40 used. Covers below AM broadcast to 30mHz.
_________________ NAVY JACK FLAG- 'Don't Tread on Me'
Top |
Skip-wave
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 6:47 pm |
Member |
Joined: Nov Fri 30, 2018 11:16 pm Posts: 539 Location: Ontario, Canada
Top |
W1GFH
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 7:51 pm |
Member |
Joined: Jul Fri 05, 2019 8:30 pm Posts: 259 Location: Lexington, MA
For BCB reception, a Ferrite antenna and a Tecsun loop.
Attachments: |
Top |
mrrstrat
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 7:53 pm |
Member |
If you see one for $40 please 911 message me I do not have luck finding them. jimbenedict wrote: mrrstrat wrote: This thread is great - like a lot of others I am struggling with the "One Antenna to rule them all" solution.
Top |
W1GFH
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 9:23 pm |
Member |
Top |
bob91343
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 9:51 pm |
As a fan of resonant antennas, I have retired my old MFJ tuners from service. I presume others have done the same. So finding a used one for a few bucks at a swap meet (if we ever have them again) should be easy enough.
There are also ham radio swap meets on the air. If you don't have a license you can still listen and write down the phone numbers of interest.
Here in California there is a swap meet on about 7240 kHz on Saturdays and Sundays at 1 PM local time. There are, I am sure, many others in different parts of the world. I would generally avoid the auction sites or the online classifieds, as those are populated by sellers with inflated ideas of the value of their stuff.
Once you contact someone you can emphasize your situation and perhaps negotiate a better price. I like to use the line 'do you want to get rid of this or not?'.
Top |
jimbenedict
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Fri 16, 2020 11:31 pm |
mrrstrat wrote: If you see one for $40 please 911 message me I do not have luck finding them. jimbenedict wrote: mrrstrat wrote: This thread is great - like a lot of others I am struggling with the "One Antenna to rule them all" solution.
Any ideas??/quote] MFJ 956 antenna tuner is about $80 new. $40 used. Covers below AM broadcast to 30mHz. Post a wanted ad at QTH.com
Top |
SX-42
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sat 17, 2020 12:30 am |
This is a lot harder than I thought it would be. A lot of choices out there and the photos are very helpful.
Great information, everyone!
_________________ Greg
Top |
W1GFH
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sat 17, 2020 1:44 am |
Member |
SX-42 wrote: This is a lot harder than I thought it would be. A lot of choices out there and the photos are very helpful.
Great information, everyone! What kind of antenna you choose depends a lot on your location. If you are out in the rolling countryside, a length of wire from the radio’s antenna terminal to a medium height tree branch would perform well. If you are on a city lot, or surrounded by suburban neighbors noise sources, you might get better results from a well-grounded, coax fed antenna placed high and away from power lines, other houses, buildings, etc. If you have 1940s receivers, I always wanted to try a doublet fed with what they called a “ twisted pair” feed line. Apparently it was a very popular type of radio antenna of the time for receiving sets, and seems to have been of a pair of insulated wires twisted together.
Top |
Skip-wave
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sun 18, 2020 5:53 am |
Member |
Also if anyone is looking to for SWL long wire kits check Frank (wdx2radio) out on the Bay. His kits are very strong, My Night Star 100 foot has gone through several Canadian ice storms with no breaks.
Skippy
Top |
mrrstrat
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sun 18, 2020 3:36 pm |
Member |
What is the proper way to feed a coax line to a long wire antenna and them to a boat anchor-type set?
Top |
Scott
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sun 18, 2020 8:41 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6352 Location: Montvale NJ, 07645
mrrstrat wrote: What is the proper way to feed a coax line to a long wire antenna and them to a boat anchor-type set? You would use a balun on each end of the coax to match impedance. I tried this method and it has performed less than stellar. Search the archives and you will get a lot of info on what others have done in this regard.
Top |
W1GFH
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sun 18, 2020 9:14 pm |
Member |
mrrstrat wrote: What is the proper way to feed a coax line to a long wire antenna and them to a boat anchor-type set? You could try it similar to a “zepp” antenna using coax instead of ladder line. I have soldered the coax center conductor to a random length antenna wire and left the shield disconnected at the top, but grounded the shield at the bottom (radio end). It’s not “proper” or perfect but it worked better than i expected. In this case, the objective is to get the antenna part of the system out to a location where there’s less noise. The coax is simply a way to get it there. One other option is a trapped doublet fed with 72 ohm coax. I used to see ads for an SWL all band antenna of this design in the 60s that used several traps to cover 1-30 MHz.
Top |
fifties
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Sun 18, 2020 11:07 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 36995 Location: SoCal, 91387
I simply used the center conductor of RG-59 Coax connected to the outdoor long wire, and then to a switch inside which connects to radios in other rooms. I tried grounding the Coax's outer braid, but it made no difference.
_________________ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\He Who Dies With The Most Radios Wins/////////////////////////
Top |
madlabs
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Mon 19, 2020 2:42 am |
Joined: Aug Thu 20, 2015 3:09 pm Posts: 1465 Location: Albion, CA, USA, 95410
CLEG wrote: i am using a rain gutter its about 70 feet total i have a wire connected too it that go/s though the window of my basement apartment it go/s into an amp supply ant tuner works great on 40 meters and other bands i am not allowed a wire ant so this is a hidden ant its the only way i can stay active as a ham Greg Can't keep a real ham down! Nice! bob91343 wrote: Here in California there is a swap meet on about 7240 kHz on Saturdays and Sundays at 1 PM local time.
One of the net controls for that net lives close to me, KB6LZW. We call him the "lazy zipper whipper". You can hear that net all up and down the west coast.
Top |
mrrstrat
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Mon 19, 2020 1:59 pm |
Member |
I think I'll give it a listen this weekend! bob91343 wrote: There are also ham radio swap meets on the air. If you don't have a license you can still listen and write down the phone numbers of interest.
Top |
Tim Tress
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Mon 19, 2020 3:36 pm |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9804 Location: Beaver Falls, PA. USA
Here at KA3JRT, the current antenna is a G5RV configured as an inverted V. I have others to put up, as I get the time; the plans are for a long-wire and a 10 meter dipole, and eventually a tower and beam.
_________________ Tim KA3JRT
Top |
SX-42
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Tue 20, 2020 12:35 am |
Hey just curious is it a plus or minus to have a cell tower 250 yards away from your home base?
Attachments: |
Top |
Dave Doughty
Post subject: Re: What Are You Useing For Antenna? Posted: Oct Tue 20, 2020 1:14 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 18167 Location: Utica, NY 13502 (USA)
SX-42 wrote: Hey just curious is it a plus or minus to have a cell tower 250 yards away from your home base? It would be a plus if the tower owner lets you attach a longwire antenna to it. It is a minus if it creates strong interference due to intermods between the carriers. I had that problem when early cell-phone antennas sprang up within 600' from my house causing a loud "hiss" in various portions of shortwave bands. But that problem has been mostly solved due to FCC regulations. The main objective of any receiving antenna is to get it away from sources of interference as far as possible. I use an abandoned telephone pole on my property with a 200' wire run out to a tree. The lead-in runs down the side of the pole and suspended inside 50' of buried 3" PVC pipe to the house. Dave
Top |
Users browsing this forum: hwhall, Majestic-12 [Bot] and 17 guests |
