It is currently Jan Sat 16, 2021 1:50 am
 Post subject: Thingamabob
PostPosted: Nov Sat 14, 2020 3:52 pm
On the front panel of my radio, there is a hex bushing thing that supports a tuning shaft where it goes through the front panel to attach the knob. I would like to find another one, but I am not sure what it is called. Does anyone know? Thanks!
 Post subject: Re: Thingamabob
PostPosted: Nov Sat 14, 2020 4:09 pm
Umm :roll: ..................... wait for it............................................Panel bushing?
In a pinch one can be saved from most volume controls or rotary switches... chas
PostPosted: Nov Sat 14, 2020 4:27 pm
The part shown in your picture is referred to as a "Panel Mount 1/4" Shaft Bushing".
You can find them here:
https://www.surplussales.com/ShaftHardw ... ftH-9.html
Remove the one shown in the picture and measure the inside diameter of the opening. The bushings
sold by Surplussales.com in the above link requires a 3/8" opening. The bushing in the above link
accepts a shaft diameter of 1/4".
I typically apply a small amount of grease to a cotton swab and insert the swab into the bushing.
I rotate the cotton swab to coat the inner bushing race with lubricant. The shaft is inserted and
any excessive lubricant around the bushing and shaft is removed with a clean cloth. This simple
application of lubricant keeps the wear between the bushing race and shaft to a bare minimum
and provides a smooth rotation of the shaft in the bushing.
Mike W5RKL
https://www.w5rkl.com
RMC(SW) USN RET
PostPosted: Nov Sat 14, 2020 8:38 pm
Thanks guys! Knew it had to have a simple description!
PostPosted: Nov Tue 17, 2020 5:48 pm
It is called a "panel bushing" or "panel bearing." I saved at least one from homebrew chassis that I bought at fleamarkets. In a pinch, you can bust up an old potentiometer and rescue the bushing. Old panel mount variable caps usually have good panel hardware that can be harvested.
Post New Topic Post Reply  [ 5 posts ]  Moderator: Sandy
Users browsing this forum: dtvmcdonald, Majestic-12 [Bot] and 17 guests
