It is currently Feb Sun 28, 2021 8:33 am
 Post subject: SX-43 Power Transformer
PostPosted: Nov Sun 15, 2020 2:58 pm
I have wanted to replace the transformer in my SX-43 for a while now.
The set requires: 117V primary, 530V/100mA, 5.2VAC/2A, 6.3VAC/4.0A
I can get a Hammond for this at a good price: http://www.hammondmfg.com/263.htm
I thought about a 270FX that is 550VCT and is a little better rated. The problem is the additional 20 volts: is it a problem and can the circuit eat it up and not worry?
I really want to avoid HV zener diode and/or resistor bleed-off solutions. I am not a fan of this.
 Post subject: Re: SX-43 Power Transformer
PostPosted: Nov Sun 15, 2020 3:18 pm
The 550V rated transformer will be fine, as long as it physically fits the slight voltage difference won't have any impact.
Rodger WQ9E
PostPosted: Nov Sun 15, 2020 4:01 pm
The extra 20 volts is not an issue. High line voltage can supply an extra 20 volts with the stock transformer. If you want to lower the HV, use a bucking transformer.
NAVY JACK FLAG- 'Don't Tread on Me'
Post New Topic Post Reply  [ 3 posts ]  Moderator: Sandy
