bob91343 wrote:
Yeah Pete maybe someone can come up with a piece or two to rejuvenate my D-104 as well.
I have the dead element in hand; I wish I knew enough to make it work again. Rochelle salt I presume. It's less than an inch across, a thin shiny square piece of stuff.
The salts dry up and it fails. I don't believe you can rejuvenate them.
Google brought 70.1 million hits for "replacement element for D-104"
Probably the first and second pages would have the best info.
https://www.google.com/search?client=fi ... +for+d-104Ceramic elements for the D-104, if you can find them, tend to last much longer.
Or, diddle with the input impedance and use some cheap dynamic mike that has decent response. And, there are mikes on the market both vintage and new that are dual impedance (high/low). Some have to be wired one or the other and some have a switch.
I still have a Lafayette crystal Lapel mike that's about 60 years old and it still works fine.
Personally, I think the D-104 is way overrated but at least it keeps one hand busy holding on to it.
