djed wrote:
You should tune for maximum signal with the narrowest filter (0.1 Kc). Then tune the BFO for the desired beat note. If the radio is aligned correctly, setting the BFO to 0 should give you zero beat at the same frequency as maximum signal with the 0.1 Kc bandwidth.
Ed W2EMN
Okay that's exactly what's happening tuned for max signal .1kc bandwidth, turned BFO to "0" position signal was at zero beat.
