rsingl wrote:
Sets like this one get a properly wired 3 wire cord when they cross my bench. Hot/black/load lead goes to the fuse and then the power switch to the power transformer, bypass capacitor after the fuse. White/neutral goes to the other connection and is not broken by any switch or fuse. Put your other line bypass cap on any convenient tie point for this lead.
The green/ground lead should be mechanically sure and securely soldered to a solid ground point.
Having a fuse or switch in the neutral lead is against NEC and an especially bad idea with metal communications receivers where a properly grounded item is often on the same bench/desk. If the receiver isn't properly grounded and a failure causes the chassis to be hot then touching the receiver and another grounded object causes the owner to become part of the circuit.
@Roger: To confirm, you saying the fuse should be moved to be in series with the switch? And does the X cap go on this lead? The Y cap on the neutral? Thanks ~Bill
