It is currently Dec Sun 05, 2021 8:40 am
 Post subject: Grundig Satellit 650: worn rubber preselector drive belt
PostPosted: Jun Tue 22, 2021 11:09 am
Goodmorning, I have a Sat 650 with a worn rubber preselector drive belt, when switch to automatic preselection often index don't reach right position. I have looked close at it and in effect have already some cracks and it has loosened. I have looked the encoder wheel and white tuning wheel how to pass through a new belt (apart white wheel have dial cords upon it too) but seems they are they are firmly inserted one inside the other. Put out the "C" holder don't have any resolutive action. Do you know procedure how to change it? Thank you F.
 Post subject: Re: Grundig Satellit 650: worn rubber preselector drive belt
PostPosted: Jun Mon 28, 2021 4:07 am
Oh Boy....I changed one out a while ago, but I'll be darned if I remember the process. I do remember it was not a hard job. I was able to buy a replacement belt on eBay.
Sorry I was not much help. I just did not want to let you go unanswered.
W2MDM
http://mikesradiosandstuff.weebly.com/index.html
Post New Topic Post Reply  [ 2 posts ]  Moderator: Sandy
cron
