It is currently Oct Wed 27, 2021 4:42 am
 Post subject: Dial indicator sticks on bottom, leans
PostPosted: Sep Thu 23, 2021 11:38 pm
Anyone know the correct fix for this on an NC-270?
The top of the indicator is attached to a bracket connected to the dial string.
The bottom has a lip that rides against the flat dial surface.
Bent the indicator out slightly from the bottom, to reduce drag?
A little lube on the bottom lip?
I don't want to experiment without knowledgeable input.
"Invisible airwaves crackle with life
Bright antenna bristle with the energy"
 Post subject: Re: Dial indicator sticks on bottom, leans
PostPosted: Sep Fri 24, 2021 12:03 am
Not familiar with this radio but I will bend the indicator just a bit and wipe on and then wipe off a small amount of light oil in the contact area. Usually works well.
PostPosted: Sep Fri 24, 2021 12:14 am
Thank you, Rich!
73
PostPosted: Sep Fri 24, 2021 12:29 am
You are welcome. I recently had this issue with a Hallicrafters S53, an S38E and a Heathkit HR10. Also, on older radios with a long scale and dial such as an SX62 or National NC303 I will wipe the track the dial indicator rides on. Sometimes the dial cord is slipping because of the drag on the indicator and this usually solves the issues without a restringing. Restringing some of these radios can be a challenge.
PostPosted: Sep Fri 24, 2021 1:24 am
Thanks again!
I certainly don't want to have to restring this beast!
Post New Topic Post Reply  [ 5 posts ]  Moderator: Sandy
