It is currently Jan Fri 21, 2022 1:00 am
 Post subject: Depth control? Notch control?
PostPosted: Oct Fri 01, 2021 3:18 am
Is my NC-270 a submarine?
I know notch has something to do with the crystal filters.
I have no Idea what the depth control is.
Can someone kindly provide a simplified explanation?
I have barely mastered the combined use of af gain and rf gain and bfo for sideband, I want to use all the tools at my disposal.
Thanks!
"Invisible airwaves crackle with life
Bright antenna bristle with the energy"
 Post subject: Re: Depth control? Notch control?
PostPosted: Oct Fri 01, 2021 5:28 am
Amateur equipment has all sorts of control acronyms like Slot Depth, Slot Frequency, IF Gain, noise limiter, noise blanker, noise silencer and many more. :D
https://www.manualman.com
PostPosted: Oct Fri 01, 2021 6:20 am
The manual has a very lengthy description of the function anduse of the notch and depth control, much more than can be summarized here. The purpose of both is to lower the strength of interfering signals which were mostly heterodynes on am or close signals on cw. If you send me a PM we can talk more about this if you have the manual in front of you so we can go through it section by section. The manual does make some assumptions of the technical knowledge of the reader so I or others can help with that background information.
W7VM
Real Radios Glow in the Dark
PostPosted: Oct Sat 02, 2021 12:35 am
Thanks, Dave.
Much appreciated.
PostPosted: Oct Sat 02, 2021 1:04 am
Gee whiz, manualman!
What's a kid to do??
PostPosted: Oct Sat 02, 2021 1:46 am
I use a "notch" control to select the frequency within the IF passband that I want to reduce and a "depth" control to determine how deep the notch needs to be. Working together, they can be used to reduce adjacent channel and other types of interference especially when used in conjunction with a Q-multiplier such as found in a Hammarlund HQ-160.
PostPosted: Oct Sat 02, 2021 2:07 am
Thank you, Dave. That makes sense to me.
As recommended, of course, I will review the manual.
Your teaching is sincerely appreciated!
Post New Topic Post Reply  [ 7 posts ]  Moderator: Sandy
