It is currently Jun Wed 23, 2021 5:37 am
 Post subject: General Electric A-63 Condensers
PostPosted: May Thu 06, 2021 2:18 pm
I am working on a General Electric model A-63 from 1935 . I am having a problem with the condensers used in this unit . I do know that GE and RCA used the same chassis at this time . My problem is the proprietary condenser codes . I can't find any info on translating the numbers on the condensers to the value for restoration replacement . Does any one out there know this code or where to find it ? :cry:
 Post subject: Re: General Electric A-63 Condensers
PostPosted: May Thu 06, 2021 2:28 pm
Here is the schematic :
http://www.nostalgiaair.org/pagesbymode ... 007753.pdf
The values are listed on the schematic, so if you go by the location of the component, the schematic will give you the value. Voltages can be estimated by the position of the component and how much voltage there will be (plate vs grid etc).
All the components are also listed further down in the document.
PostPosted: May Thu 06, 2021 2:31 pm
Do they have the stock no. codes?
Jay
PostPosted: May Thu 06, 2021 6:28 pm
Ok thanks for this info but the numbers I am dealing with are : 66139-1 ,G27, G21 , G5 ,G2 , 39 on the condensers....
PostPosted: May Thu 06, 2021 6:57 pm
I think the "G" I am seeing is a "C " and the numbers are the location designation ... now I can continue with no problems ... thanks for your help .... I don't have this info ...
PostPosted: May Thu 06, 2021 7:03 pm
I did notice that the parts list does not match my model I have about 12 condensers to replace ... the parts list only has 9 condensers ....
PostPosted: May Thu 06, 2021 7:46 pm
Some will be trimmers, tuning caps, filter capacitors, and there might be a small mica cap buried in the osc section somewhere.
PostPosted: May Thu 06, 2021 8:59 pm
I am checking all paper condensers .... I should clarify a few things .... this is a Canadian model using glass tubes
tube line up : 6A7 , 6K6 , 6K6 , 6B7 , 6F6 , 80
LW , SW ..... 1935
PostPosted: May Thu 06, 2021 9:15 pm
It is not the same as the American model ....
PostPosted: May Thu 06, 2021 9:39 pm
https://www.radiomuseum.org/r/canadian_g_a63.html
All component values are shown on the schematic.
http://pacifictv.ca/schematics/rca-a63d ... ubmit&db=5
Mmfd...
viewtopic.php?p=3318709#p3318709
Alignment instructions attached below.
Alignment. General Electric. A-63.pdf [1.26 MiB]
Downloaded 13 times
PostPosted: May Fri 07, 2021 12:44 am
The most appropriate check for wax paper caps is in the counting. You look at the schematic and the parts list & ensure you have that number consigned to the bin.
Trap: The capacity may read right. However, if tested at there working volts or running voltage, using an insulation tester, things will be very different. If there is any leakage shown; here they go in the bin. Leakage can seriously impinge on bias an consequentially, performance.
Marcc
PostPosted: May Fri 07, 2021 1:24 am
Your so right ... I tried that , what I found out the value on my ESR capacitor checker did not match what was on the schematic....
PostPosted: May Fri 07, 2021 12:30 pm
With the Insulation tester, one does not use it on electrolytics. The Lafayette info here says screen decoupling should not be below 50Meg and coupling 200megohms. The probability of finding any Wax Paper types that good is remote and several Bakelite clad Micamold are not Mica, it's a Trademark. A leaking cap is not to be trusted. Electrolytic's need to leak because of what they are, but even that has a limit.
Marc
Post New Topic Post Reply  [ 14 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: JnTX, scstill, stone3035, westcoastjohn and 55 guests
