It is currently Dec Tue 06, 2022 12:27 am
 Post subject: Philco 46-1201 Phono/Radio Question
PostPosted: Oct Mon 11, 2010 4:01 pm
Hello,
I'm restoring a Philco "Bing Crosby" 46-1201 phonograph. I replaced the crystal cartridge with an Astatic 8978B. The problem is the cartridge causes the sound to overdrive. I already toned it down with a resistor installed at the terminals where the tone arm wires go but I'm still not happy with the sound. It distorts, especially when the music has multiple voices or solo piano. Any suggestions?
PostPosted: Oct Mon 11, 2010 5:12 pm
Silent Key
If the new pickup is the problem, try using 2 resistors:
In series with the signal wire (center pin) 1 megohm
Across the radio side of that resistor 47 kohm to ground.
If this attenuates sufficiently, but seems to lack highs,
connect 470 Pfd across the 1 meg resistor.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Oct Mon 11, 2010 7:54 pm
Thanks. I'm confused though. I'm pretty new to this. I've posted a photo of the terminals. Can you tell me where each of the resistors you're talking about go? In the photo, from left to right, numbers one and two are the tone arm leads and number three is ground. I think four is radio.
Thanks for your help.
PostPosted: Oct Mon 11, 2010 7:55 pm
The problem is that now the pre-amp stage does not match the impedance and output of the new cartridge. You will need to re-design the amplifier.
Post New Topic Post Reply  [ 4 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: bhnsedcvb657, Brobertson, Jthorusen, Majestic-12 [Bot] and 9 guests
