It is currently Jul Sun 05, 2020 2:09 pm
 Post subject: Easy Delco Car Radio Dial Light Question
PostPosted: Nov Fri 15, 2019 2:41 pm
This will probably be an easy one for you guys that service a lot of car radios.
The radio is a Delco 7289373, a basic AM set out of a mid-60's Oldsmobile.
The broken dial lamp that was in it was a 1893. Is this correct lamp type for these radios?
Thanks.
Paul
...... how hard can it be?
 Post subject: Re: Easy Delco Car Radio Dial Light Question
PostPosted: Nov Fri 15, 2019 3:10 pm
Yes. It's a 14V, 5W, bayonet-type lamp. Should be a great choice for a car radio, where the nominal 12V
power bus typically runs around 13.5V with the engine running.
PostPosted: Nov Fri 15, 2019 7:55 pm
Most car 12v radios used either 1891(.24A @ 2CP) or 1893(.33A @ 2CP). I believe the 1893 is considered a heavy duty bulb.
PostPosted: Nov Fri 15, 2019 8:03 pm
Thanks, Guys.
I have a box of 1893 lamps on the way.
Paul
PostPosted: Nov Sun 17, 2019 6:48 am
1893 is the correct lamp per the Delco parts list for 7289373
Meade
Users browsing this forum: Dennis Banker, Google [Bot], sawblade54 and 29 guests
