It is currently Aug Thu 13, 2020 3:35 am
 Post subject: How I repaired a switch with a broken tab
PostPosted: Nov Tue 19, 2019 2:21 am
Hey guys, I just successfully repaired my Philco 38-3 AC/Tone control 3 position switch with the help of Mark Oppats advice. I just used a feeler gauge, a dremel tool, some sharp drill bits and a package of BBs that would go into a BB gun since I lost my original ball bearing. I used the .33mm size feeler gauge but next time I would try a bit thicker. I’ll post some pictures and a link to the video. If anyone needs help with a similar repair let me know. Anyways it worked out nicely. Here is a video of it in action after the repair:
https://youtu.be/xe3_aazel_E
[ Play Quicktime file ] trim.9B69D0F3-344B-41B9-9E15-8FBA5D8385D6.MOV [ 4.3 MiB | Viewed 670 times ]
 Post subject: Re: How I repaired a switch with a broken tab
PostPosted: Nov Tue 19, 2019 4:44 am
Very nice repair work!! Now pat yourself on the back...... :P !
Thanks for sharing - and the video too!!
Brian
PostPosted: Nov Wed 20, 2019 6:06 am
GREAT JOB John !
If that spring steel part is not strong enough, the ball bearing will want to "jump" out of the hole you drilled for it to ride in when actuated quickly. So as long as a kid doesnt twist that knob fast, you will be ok.
The Zenith 85-109 "Off-On-Local Distant" switches are just like this too. The same type of part fails, but its a bit different shape. You could do well to off this service here on ARF or make up a listing for Ebay and do it., lots of these have failed for the same reason and can be fixed.
Mark Oppat
PostPosted: Nov Wed 20, 2019 11:13 am
Great job!
http://pages.suddenlink.net/davesradios/
PostPosted: Nov Thu 21, 2019 6:00 am
If you scratch that end cap more with an X-acto knife, it will take solder better and hold stronger. No need for the wire.
Mark Oppat
Post New Topic Post Reply  [ 5 posts ]  Moderators: Norm Leal, Marcc
Users browsing this forum: Google [Bot], jmsent, Tom Albrecht and 25 guests
