It is currently Jul Wed 15, 2020 9:36 am
Post New Topic Post Reply  [ 140 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: Radiola Grande Restoration
PostPosted: Apr Sat 18, 2020 5:18 pm
More specifically, the grids of all 3 audio tubes should be -3.98v. Somehow the 1st audio tube grid is connected to 48 volts, according to your measurements.
Maybe this will help. Photo courtesy of Radiomuseum.org.
Jeff
“Nothin’s worth nothin ‘till somebody wants it.”—Irv Metter
PostPosted: Apr Sat 18, 2020 9:12 pm
I'm getting 90v at the #1 connection of the H transformer where you have it marked 45v, meter negative lead connected to B- on the ARBE. All other connections check the same as you have marked them.
Dan
Museum Curator
https://roaringtwentiesantiqueradiomuseum.com/
PostPosted: Apr Sat 18, 2020 11:22 pm
Could there be some confusion in the re-assignment of B voltages to the multiple (unused) A+ connections. Since an internal "B" battery is not in use?
Chas
PostPosted: Apr Sat 18, 2020 11:37 pm
Can you post a photo of that area? Zoom out so all 4 tube sockets can be seen.
Do you have B- connected to A- at the arbe? That may be a mistake on my part
I am confused as to how there can be 90v on terminal 1 of H and 45v on terminal 2. Should be the same voltage at both terminals.
Yesterday you said audio tube 1 had 48 volts on grid pin; today it is C- (3.9v)?
Jeff
PostPosted: Apr Sun 19, 2020 12:51 am
Dan
Museum Curator
PostPosted: Apr Sun 19, 2020 12:59 am
B- and A- are not connected at the ARBE.
atwaterkent1 wrote:
Dan
Museum Curator
PostPosted: Apr Sun 19, 2020 1:07 am
atwaterkent1 wrote:
Because, if true to the schematic, that connection is accomplished in the radio...
So where is the 45 volts going if it is not to the detector B+, accidentally to the C- connections?
If true, what has become of the C- connected to the +90 for the first AF? But that is common to the PP output. Oh my?
Chas
PostPosted: Apr Sun 19, 2020 2:36 am
Chas was right and I stupidly missed it. Heyboer rewound H transformer with leads in different places. Okay, I'm an idiot. I can get a weak but clear signal through the regular headphone jack now and can tune different stations. Amp section still not working. Transformer voltages on the two transformers Jeff marked in photo are correct. Current tube voltages as shown....
New photo with H transformer connections corrected.....
Dan
Museum Curator
PostPosted: Apr Sun 19, 2020 2:32 pm
Does it work now?
PostPosted: Apr Sun 19, 2020 3:39 pm
MRX- As I wrote in my post, the amp section still isn't working. No sound from speaker and very weak sound from headphones.
Dan
Museum Curator
PostPosted: Apr Sun 19, 2020 4:06 pm
Now, try it as a 2 tube radio. Disconnect 2 from the K transformer and connect phones between disconnected wire and 4 on K transformer.
Jeff
PostPosted: Apr Mon 20, 2020 12:32 am
Nothing Jeff.
Dan
Museum Curator
PostPosted: Apr Mon 20, 2020 2:45 am
"nothing"...
Not good, placing the 'phones in series with the output winding of the 1st audio output and with the voltages given, means there is a problem other the tuner is not regenerating enough to have any kind of signal.
A "live" audio can be inserted by making up a voltage divider for the audio output of the RF generator, remember there is no attenuator. Select any 1K resistor and any 10k resistor and solder them in series add a .01/630 volt at that junction. Connect the 1k resistor free end to the ground of the audio output take a ground lead from their too. Connect the 10k resistor to the high or other jack of the audio output. Add an extension lad to the cap and put a probe on it. Take the ground wire from the audio and connect that to A+
Note I want to use A+ as the instrument ground not B- keep that in mind.
Turn on the generator and be sure controls are set to generate an audio signal. Test by putting the audio signal on the Baldies, they should whine at 1khz. if not find out why.
Reconnect the B+ to that transformer, power the set and turn up the filaments. now touch the cap probe to the plate of tube #2, there should be a loud whine in the speaker...
What you have made is an audio signal injector, the detector is the radios speaker.
Probe terminal one or terminal 5 of transformer "L" or the plates of tube 4 and tube 3. You should get equal volume tone from each...
Now probe the grids of tube 4 and 3, equal but louder volume.
Now probe terminal 4 of transformer "K" or the plate of tube 2, the volume should be even louder.
If there has not been a progressive increase in tone loudness then there is a flip in one or both the transformer windings that have two leads joined.
It will take AC voltmeter measurements or the two channel scope to determine, first if transformer "K" is flipped and a reverse tone injection technique to determine if transformer "L" is flipped. Using the tone as the AC source.
Your capacitor probe is safe will not pass DC but will store a tiny charge when used to touch a B+ connections. It could nip if you get into contact.
Chas
PostPosted: Apr Mon 20, 2020 6:08 pm
atwaterkent1 wrote:
Nothing Jeff.
Try Chas' test. Also, refer to page 4 and see if it still works as a 1 tube radio.
Looking at your photo, the H transformer is numbered (from the top) 4,2,1,3. 2 and 1 should be the primary; 4 and 3 should be the secondary. What is the resistance, 2 to 1 and 4 to 3?
Are the 2 large black wires in the foreground of your photo the "C" battery connections?
Jeff
PostPosted: Apr Tue 21, 2020 2:03 am
Didn't get much time to work on radio today. Busy day and got a new radio in and wanted to check it out to let the seller know everything is ok.
On H transformer:
3 + 4 = 1.964k ohms
1 + 2 = .485k ohms
Wires in foreground are C power connections.
Tried the one tube radio test, got nothing until I disconnected the +90v, then it worked. I think I'll go to Costco and get the one gallon bottle of aspirin. :lol:
I should have more time to do the other stuff tomorrow, still recovering from last Monday.
Dan
Museum Curator
PostPosted: Apr Tue 21, 2020 3:49 am
On K transformer:
3 + 4 = 1.964k ohms
1 + 2 = .485k ohms
Umm, why are readings taken across the windings? If this is a leakage test, failed miserably...
Check the navigation of the transformer markings and actual connections. Do the actual connections conform to the schematic, wire for wire, label for label?
Oh, these are DVM readings?
Chas
PostPosted: Apr Tue 21, 2020 3:56 am
Sorry Chas, H transformer.
Dan
Museum Curator
PostPosted: Apr Tue 21, 2020 11:10 pm
atwaterkent1 wrote:
On H transformer:
3 + 4 = 1.964k ohms
1 + 2 = .485k ohms
Transformer numbers are good.
On one tube test, did you do it exactly as before? That is, disconnect wire to H2 and connect phones to that wire and H1? I don’t see how the 90 volts connected or disconnected would have any effect. If you did not disconnect anything, just clipped in the phones to H2 and H1 then somehow the 90 volts is getting into the 45 volt circuit.
Jeff
PostPosted: Apr Tue 21, 2020 11:25 pm
I had the C voltage on. I just tested it again with the 90v connected and the C voltage off and it works great as a one tube. When I turn on the C voltage the signal cuts out. With the C voltage on and the 90v disconnected, it works again. :?
Dan
Museum Curator
PostPosted: Apr Tue 21, 2020 11:41 pm
Chas wrote:
"nothing"...
Chas
One end of each resistor and both ends of the cap all soldered together?
Dan
Museum Curator
Post New Topic Post Reply  [ 140 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Users browsing this forum: No registered users and 18 guests
