It is currently Jul Thu 02, 2020 9:13 pm
 Post subject: Please, where do I connect this cable?
PostPosted: Apr Wed 08, 2020 3:24 am
Dear Friends:
First of all, sorry for my English; it is very bad.
I am restoring a Graetz Melodia 1118 radio. I am redoing the power supply with new components. But in the power transformer I find a cable that I don't know where to connect.
I show you the schematic diagram so you can help me.
Does it connect to ground? At what point?
Does it connect to earth? But the radio doesn't have a eart wire.
Thanks for the help you can give me.
A cordial greeting,
Sebastián
File comment: Transformer diagram
 Post subject: Re: Please, where do I connect this cable?
PostPosted: Apr Wed 08, 2020 4:14 am
Not certain, but it looks like that wire should go to chassis ground like the PS filter caps.
PostPosted: Apr Wed 08, 2020 4:24 am
Yes, it is the metal chassis.
If you are familiar with other symbols, it is the same as this:
or this
PostPosted: Apr Wed 08, 2020 5:21 am
Thank you for your answers!
It is a blue wire that seems to come out of the transformer core (according to the diagram).
I hesitated because there is also a ground symbol on the primary side of the transformer.
That ground symbol is the only one used in the entire radio circuit as a signal ground too.
I didn't want to break anything, so I asked.
Thank you!
PostPosted: Apr Wed 08, 2020 5:43 am
This is called a Faraday shield and reduces noise coupling between primary and secondary windings of transformer.
PostPosted: Apr Wed 08, 2020 6:20 am
Thank you very much, Rich!
So should I connect that wire to safety ground? that is, the green-yellow wire from the outlet? But the radio has no safety ground.
Can I then connect it to the ground of the filter capacitors of the power supply?
Thank you!
PostPosted: Apr Wed 08, 2020 5:22 pm
Not electrical safety ground. Radio ground (blue).
PostPosted: Apr Wed 08, 2020 7:52 pm
Thank you very much, AJJ! I will do it.
Greetings,
Sebastián
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: ArnoldJRimmer, BasinStreetDesign, fifties and 15 guests
