It is currently Jun Wed 03, 2020 4:40 am
 Post subject: high voltage on 2nd detector
PostPosted: Apr Wed 08, 2020 12:18 am
Hello, i have a Crosely 516. I have high voltage on plate of the 2nd detector, 76 tube. I have 150V. and schematic says it should be 86V. The cathode is also about twice as high. I changed all caps and a few resistors. All other tubes measure in spec. I also changed the damaged speaker and output transformer. It came from another Crosley. Could that high voltage just be a bad tube. I have no way to test tubes. Thanks. Gary Ketterman.
 Post subject: Re: high voltage on 2nd detector
PostPosted: Apr Wed 08, 2020 12:31 am
Hi and Welcome Gary
Crosley 516 with 76 tube has a 300K plate resistor. This large of a resistor makes a voltage divider with the meter. Older meters loaded voltage more than your modern one.
Does the radio operate?
http://www.nostalgiaair.org/pagesbymode ... 003374.pdf
PostPosted: Apr Wed 08, 2020 12:39 am
If the cathode voltage is 2X too high, that's more of a concern (lower impedance--less dependent on type of meter.) But: "does it work?" trumps other questions.....
PostPosted: Apr Wed 08, 2020 1:03 am
Yes, the radio picks up about 3 stations now.
Users browsing this forum: AJJ, Brett_Buck, Google [Bot], KX5JSC, tym and 16 guests
